Come on ride the train, the valve train!
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 24
Thread: Come on ride the train, the valve train!
  1. #1
    Sit speling cheker BTK Expert 87handmedown's Avatar
    Join Date
    May 2008
    Location
    McPherson, KS
    Posts
    427
    Default Come on ride the train, the valve train!
    Meh, so it's not my best title. I know someone out there laughed.
    Checked the clearance on my valves tonight as the bike has been sporatically running out of power. My results are as follows
    Cylinder________#1 ______ #2 ________ #3 _______ #4
    Inlet__________0.13 _____ 0.12 _______ 0.16 _____ 0.10
    Exhaust_______0.17 ______ 0.20 ______ 0.18 _____ 0.18
    So it's not what I expected at all. Only one valve is out of spec, three are close, and the rest are all fine. It's just wierd, some times the bike will run fine, other times it acts like it's running out of power. Example, Sunday afternoon I had the throttle wide open and in fifth gear, it wouldnt' pull itself past 7000rpm. However, Wednesday on the ride home from work, I ran 90mph (again around) 7000rpm and I was only at 3/4 throttle and it had plenty more in it. Weather conditions were extremely similar in both cases as was the road/terrain.
    I guess I just expected it to be farther out of spec than it is. Sporatic problems are the WORST to try and solve. But I'll worry about the big picture later. Right now I'm just looking for any advice or direction to take as far as bringing the valve train back into adjustment.
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Navy Vet Search & Rescue BTK Expert StarGate's Avatar
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,894
    What are the specs for intake and exhaust on your bike?
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
  4. #3
    Join Date
    May 2008
    Location
    McPherson, KS
    Posts
    427
    Oh sorry, I thought they were all the same. 0.08-0.18mm is what the book says.
    And here it is in my 100% uncertified 'feshional mechanics shop. The "pro" is dropped off because I don't get paid. lol
    Nate was right. It really isn't that hard at all to do, and all my rubber gaskets have gotten hard so they do need replaced.
  5. #4
    Uncle Bob's Love Child BTK Expert Ronmac1118's Avatar
    Join Date
    Jul 2007
    Location
    NW GA
    Posts
    284
    Gas Man, nothing but high test premium, gas now is rotten, trashy, weak
  6. #5
    Join Date
    May 2008
    Location
    McPherson, KS
    Posts
    427
    I'm curious as to how switching to a higher octane gas is going to solve my problem. All I would be doing is going to a fuel that is less likely to autoignite.
  7. #6
    Join Date
    May 2008
    Location
    McPherson, KS
    Posts
    427
    Should I bother messing with the 0.16 valve on the intake side? Anyone have any tips for doing this? It seems pretty straightforward but I was just wondering.
  8. #7
    Member BTK Expert
    Join Date
    Mar 2006
    Location
    KCK
    Posts
    19,728
    Valves only get tighter as time goes on.
  9. #8
    Member BTK Expert
    Join Date
    Mar 2006
    Location
    KCK
    Posts
    19,728
    Quote Originally Posted by 87handmedown View Post
    Most owners of these only run 87 octane. Not because they're cheap, but because the bike runs better on it. Mine runs like doo doo on anything except 87.
  10. #9
    Join Date
    May 2008
    Location
    McPherson, KS
    Posts
    427
    Ok, so I removed the cam, buckets, and shims and then looked at what was stamped on the shims. The numbers on the exhaust are 250, 245, 245, and 250. I assume this means 2.50mm, 2.45mm ect... correct?
    So if I take the two outside shims and put them on the two inside valves, that will bring the clearance in on them from .20 and .18 to .15 and .13 respectively right?
    And then I should order the 2.55mm shims from Z1 to bring the other two within tolerance?
    Just trying to make sure that I don't do this wrong.
  11. #10
    Join Date
    May 2008
    Location
    McPherson, KS
    Posts
    427
    Quote Originally Posted by A2rider View Post
    That's exactly what I thought. No difference in flame speed or energy released.
  12. #11
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,894
    I wouldn't touch the exhaust side. They are all at the loose side of tolerance now or just above it which is the preferred setting.
    I would go with a .05 smaller shim on #1, #2, and .10 smaller on #4 inlets then button it back up and ride it.
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
  13. #12
    Join Date
    May 2008
    Location
    McPherson, KS
    Posts
    427
    Quote Originally Posted by StarGate View Post
    Wait a sec, I'm extremely confused now. I thought everything got loose as time went on... thus I would have to put bigger and bigger shims in the valvetrain to take up the slack. Meaning as time goes on, a .18 gap turns into a .22 gap and a .12 gap will grow to a .15 but you guys are saying that it's the other way around.
    Am I reading this correctly?
  14. #13
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,894
    Yes you are reading correctly. With more wear the valve will sink farther into the head which closes the gap between the cam and valve thus making the gap smaller. If you adjust it for maximum gap then ride the poo out of it, the gap will only get smaller meaning that your adjustment to max will be within spec for a longer period of time.
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
  15. #14
    Join Date
    May 2008
    Location
    McPherson, KS
    Posts
    427
    Ah! Thank you for explaining that too me. I had it all backwards. In addition to this being my first bike, it is also the first overhead cam engine I have worked on so thanks for setting me straight!
    I'll order the correct parts tonight and then get to taking the intake apart tomorrow!
  16. #15
    KZ Kool! Forum Supporter Nate's Avatar
    Join Date
    Oct 2004
    Location
    Marysville, KS
    Posts
    2,818
    That looks familiar, Orry!
    In my estimation, increasing the clearance on 1, 2, & 4 intakes won't hurt anything.
    As for it running poorly, are you 100% certain the fuel tank cap vent passage is clean? I spent about a half a can of carb cleaner on my SR cap making sure it was clear and pulled the cap assembly apart to clean the 650B's vent.
    Beyond a fuel blockage, the only other thing would be electrical. A coil could be breaking down or a condenser getting weak and not allowing the coil to charge to full strength thus weakening the spark.
    Once you get it back together warm it up and do a compression test. You should see about 150 PSI on all four cylinders.
    As to why a bike will run better on "premium" gas may well be that the gas is indeed better or more stable than the cheap stuff from a given company. Many companies claim various blends and it would stand to reason that they may treat the "premium" gas with a bit more care than just adding more octane to it. Doing so also allows people to believe that a higher octane rating equals higher performance gasoline, when actually a higher octane rating is required for a higher performance (compression) engine. People have come to believe that the tail wags the dog.
    "Riding is the reward for time spent wrenching."
    "Wrenching is the result of time spent riding!"
    KZ650
  17. #16
    Join Date
    May 2008
    Location
    McPherson, KS
    Posts
    427
    It's actually spelled Orrie, but the fact that you tried is all I really care about anyways.
    Please elaborate on this fuel tank cap vent. I was unaware that there was anythign to clean. How do I clean/disassemble it? To be honest, it does act a lot like a fuel problem.
  18. #17
    Join Date
    Oct 2004
    Location
    Marysville, KS
    Posts
    2,818
    Orry, Orrie, Nate, Nat, it's all the same to an old guy!
    There is a small passage that allows air into the tank as the fuel level drops. Likewise, as the fuel expands on a warm day or contracts when it cools, air is forced out or drawn in respectively. That's how moisture gets into an otherwise "sealed" tank and rust forms. Rust and dirt can also collect through that passage partially clogging it.
    Now, your bike being an '82 has a different style cap than I'm familiar with. I'd bet that Andy has a good idea on how to clean it. All I can say is remove the gasket and look for a tiny hole or series of tiny holes (maybe three) and shoot carb cleaner into them followed by shots of compressed air. Also, a new cap gasket maybe the answer as a new one won't deform and perhaps block the vent(s) (that's just a theory of mine as I have no proof that could happen). Finally, when you look at the underside of the cap, you may find it assembled with screws (650B) or as a padlock (SR). I'm no locksmith so I didn't attempt to disassemble the SR cap, but the 650B cap was taken apart with ease and cleaned. Yes, there was gunk in each.
    One telltale sign that it's plugged is that right after a ride of some distance you open the cap and you hear air rushing into the tank. Also, on the day it was sluggish, had you ridden farther than on the day it ran fine? At some point the fuel flow will stop completely until some air can be let into the tank and it can return to atmospheric pressure.
    KZ650
  19. #18
    Join Date
    May 2008
    Location
    McPherson, KS
    Posts
    427
    Thumbs down And the hits just keep on coming
    Well, I think I really ****ed myself this time. I was taking the intake cam off when I dropped one of these little guys down into the slot where the timing chain runs.
    Please tell me that it went straight to the oil pan and that it's not stuck halfway in the block going to cause me problems later. Do these bikes have magnetic plugs that it'll stick to at the bottom? I probably need to remove the exhaust and then drop the pan to find out where it is don't I?
    Taking any and all possible suggestions on how to solve this one.
    Back to the original problem, the shims on the intake valves going from left to right, which is #1-#4 cylinders right?( don't want to **** anything else up) are 2.50, 2.55, 2.50, and 2.45.
    So if I take the 2.45 shim and put it on the #1 intake valve inplace of the 2.50 shim, and then take that 2.50 shim and put it on the #2 intake valve, I'll only need to buy a 2.35 valve for the #4 intake valve correct?
  20. #19
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,894
    Correct and before you pull the oil pan. I've dropped a bolt in mine before and was able to fish it out with a magnet. You can use a magnet thats attached to one of those telescoping rods. You might just get lucky and snag it if you have a lot of patience.
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
  21. #20
    Join Date
    May 2008
    Location
    McPherson, KS
    Posts
    427
    Well good news! I was playing with my little magnet on a stick tool and managed to grab the bushing as it was resting on top of the crankshaft gear. I had already drained the oil but that's ok... bike needed an oil change anyways. So now I'm back to square one!
    Only question I've got right now is, on the timing chain tensioner, there are two bolts that hold it on. One of these, the top bolt, had a washer, the bottom bolt did not, or at least it didn't when I took it off. Should both bolts have a washer, or just the top one?
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. How many fellow riders use helmets?
    By greeneyess82 in forum Kawasaki Cruisers
    Last Post: 06-03-2009, 09:45 PM
  2. Ride Report: My first Saddlesore 1000-Texas Tour-56k warning
    By thedude in forum Kawasaki Cruisers
    Last Post: 06-20-2008, 01:01 PM
  3. We went on a Demo Ride today
    By LordGT in forum Kawasaki Cruisers
    Last Post: 04-23-2007, 03:51 PM
  4. Replies: 4
    Last Post: 04-12-2007, 04:11 PM
  5. SOCAL Julian Ride
    By sdbrit68 in forum Rides, Events and Rallies!
    Last Post: 03-12-2007, 09:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
