Old 08-04-2008   #1 (permalink)
calf82LTD
Default '82 750 LTD: Replacing float valve needle & seat
Hi everyone I was just wanting everyone suggestions about replacing float valve needle & seat in one of my carbs. Is this a detailed operation, other words should a mechanic take care of it or is it something I could do (I am a novice, but have done some work on the bike i.e. oil changes, tach line replacement).
I would appreciate anyones thoughts and instructions
calf82LTD is offline   Reply With Quote
Old 08-04-2008   #2 (permalink)
calf82LTD
One last thing, is it ok to ride the bike even though carb is leaking?
Old 08-04-2008   #3 (permalink)
Alizard
The Cruising Gunsmith
I would not ride a bike leaking gas. The fire that is likely to start will be about four inches away from the family jewels.
Changing the needles and seats is easy if you can get the bowls off. You do need to adjust the float levels with new needles and seats.... which is probably the problem you have which is making the ones you have leak.
Alizard is offline   Reply With Quote
Old 08-04-2008   #4 (permalink)
calf82LTD
Thanks for the advice. One last thing can I do all this will keeping the carbs on the bike?
I have the Clymer book but I was wanting to know if any onw knew of detailed instructions on the web?????
Old 08-04-2008   #5 (permalink)
snardle
Bob
snardle's Avatar
be careful when you take the bowls off if the gaskets don't seat up properly when you put the bowls back on you might have a problem with the engine surging.
snardle is offline   Reply With Quote
Old 08-04-2008   #6 (permalink)
JG6_oddball
Clutch Cadet
JG6_oddball's Avatar
interesting...are you saying this could be a possible airleak if the seal is not proper? i ask because I never considered that before..but had surging problems in the past with carb cleaning/rebuilds
S!
81,CB750K
78,GS550
8?,CX500
83,KZ750
81,KZ440
81,XV920
86,ZG1000
82 XJ1100 Maxim (current)
JG6_oddball is offline   Reply With Quote
Old 08-04-2008   #7 (permalink)
Alizard
I can on my 750 twin with BS-38 carbs.
Which carbs do you have?
Old 08-04-2008   #8 (permalink)
Alizard
S!
I have never heard of that. The bowl seal to the carb body is not a pressure seal since the bowl area is vented to the atmosphere, it's basically open at the top by design.
Old 08-04-2008   #9 (permalink)
calf82LTD
Bounty, is it fairly involved to adjust float levels with new needles and seats? Can I do all of this w/ the Carb still on the bike?
Just wanted to note that I have a 4 not a twin
Old 08-05-2008   #10 (permalink)
gpzrocker
Clutch Cadet
I think you could service this on the bike, but not something I would want to do. I would think that you would need a correct size punch to push out the pin, and the pin holders on the BS's break easily, especially for a ham fisted beginner like I was/am. Outside carbs are obviously easier.
I know the concern, I anted up for a new set of boots on my air box, and can get the carbs in and out in like 10 minutes. Before, well, they never went back on with the original boots.
gpzrocker is offline   Reply With Quote
WTB: 90 Ninja 750 Corbin seat chulo_d Accessory Swap Meet 4 05-09-2006 08:14 AM
88 750 rear seat mods ???? ghopwood Kawasaki Streetbikes/Sportbikes 0 06-03-2005 07:32 PM
My New Corbin Seat - 92 Vulcan 750 tampametal Want to show off your ride? 9 03-11-2005 12:40 AM
New rider - '89 Vulcan 750. Also - getting under the seat? HowardC Main Lobby 5 11-10-2004 10:20 AM
Replacing Sprocket and chain on 87 ninja 750 Ksnarf The Mechanics Corner 2 04-25-2004 05:48 PM
