Old 08-08-2008   #1 (permalink)
Ace Cafe
Default KZ1000 - oil pressure reading
I've searched threads and have found minimal info regarding what kind of oil pressure KZ1000's run. I've got a guage on my 80 LTD and at idle (1000rpm), its running around 1 psi...ramps up in the 3-5psi range at about 3000 rpm. Bike guys i've talked to are surprised its so low...they're thinking it should be reading 20.
Do I have pump issues or is this normal?
Ace Cafe is offline   Reply With Quote
Old 08-08-2008   #2 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
From what I've been able to find out 2-3 psi is pretty normal for our bikes. I was surprised to learn this but have verified from a few pretty good sources.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 08-08-2008   #3 (permalink)
MFolks
Wants better weather!
Checking my shop manual on my 82 GPZ1100 B2, it said at 3k and 140 F it should be 2.8 psi.
Old 08-08-2008   #4 (permalink)
MFolks
These engines have pressed together crankshafts with roller bearings requiring much lower oil pressure than the standard friction bearings needing an oil film to function.
Old 08-08-2008   #5 (permalink)
W-P Bill
Way Too Much Free Time
W-P Bill's Avatar
Sounds pretty normal to me. Also keep in mind most oil pressure gauge mechanicals are intended for car engines, there isn't enough volume in motorcycle specific gauges for economy of scale to offset higher production costs. These car gauges are intended to operate primarily in the 20-60 psi range and calibrated that way, so they can be wildly inaccurate in the single digit range where most bikes operate.
Yeah, that oil pressure gauge you bought for your bike may be much smaller than a car gauge, but the inner workings are the same, more often than not.
If your low numbers still worry you, go up in oil viscosity. That'll bump things up 2 or 3 psi for you. I run 10W-40 for most of the year but ramp up to 20W-50 for the summer. Just make sure to change back when the summer is over, unless you have a kick starter to stir things up before pressing the magic button.
Except for my gravedigger, she runs 20W-50 for three seasons and straight 50 for the summer. Old tech, don't ya know...
You can only be young once, but you can be immature forever!
W-P Bill is offline   Reply With Quote
Old 08-08-2008   #6 (permalink)
StarGate
StarGate's Avatar
I've seen someone selling gauges and kits with a VDO gauge for 1-15 psi on ebay. Don't know much about them though.
Mike
Original Owner
1981 KZ1000-K1 LTD
Photos
Old 08-09-2008   #7 (permalink)
Ace Cafe
thanks for all your responses...big help
yea, i saw the VDO set up selling on ebay...go to summit, vdo guage is 19 bucks, plus about 5 in fittings, much cheaper than the $60 on ebay.
Old 08-09-2008   #8 (permalink)
StarGate
StarGate's Avatar
Did you mean summit racing? I can't find any that register low range psi. 0-80 is the closest I found.
Mike
Original Owner
1981 KZ1000-K1 LTD
Photos
Old 08-09-2008   #9 (permalink)
MFolks
I've got an older gauge set up on my GPZ1100 B2 that goes from 0-30 psi made by VDO.
Old 08-09-2008   #10 (permalink)
Stormdragon
Can't find time to ride
Stormdragon's Avatar
You're off in 2-stroke territory there. While I'm sure it's been done, I can't think of a single Japanese 4 stroke that has a pressed together crankshaft. Okay, the racing only 1960 era Honda RC series had pressed cranks, but meanwhile, back in the real world...
It's not how fast you go, it's how little you slow.
Stormdragon is offline   Reply With Quote
Old 08-10-2008   #11 (permalink)
StarGate
StarGate's Avatar
Actually you need to research more. Mine actually slipped and was replaced on factory recall for that and I paid extra on top of what the warranty covered to have the new one welded and rebalanced.
Mike
Original Owner
1981 KZ1000-K1 LTD
Photos
Old 08-10-2008   #12 (permalink)
Jeff.saunders
Obsessed by Z1's
Jeff.saunders's Avatar
Send a message via AIM to Jeff.saunders
You need to do some more reading...
All the Kawasaki Z1, KZ900, KZ1000, KZ1100, all the early GS1000's and much more have the pressed together crank with caged roller bearings.
2-3 psi oil pressure is normal
jeff@z1enterprises.com 1973 turbo'd Z1, 1973 stock Z1
www.z1enterprises.com
Jeff.saunders is online now   Reply With Quote
Old 08-12-2008   #13 (permalink)
Ace Cafe
yea, it was from Summit Racing...0-15 psi. May give them a call if you're not seeing it. I think i pulled it up online.
Bike Oil vs Car Oil... Brett The Mechanics Corner 55 08-05-2008 09:24 PM
1978 Kz1000 Fork Oil Capacity RiverCitySlim Vintage Motorcyle Info 2 06-30-2008 03:52 PM
A story about engine oil 07Ninja250 The Mechanics Corner 11 06-11-2008 09:52 PM
80 KZ1000 Oil Gallery bolt size renobruce Vintage Motorcyle Info 0 10-11-2006 09:46 PM
How to change oil on 99 ninja 500R mixery2k The Mechanics Corner 8 01-22-2004 06:49 PM
