I was working on the bike sunday and got a little scare,,,the bike was idling and after a few mins it began to blow white smoke from both exhaust pipes..it does not smell like gas/oil/antifreeze...but whne this happens it start running a little rough and will die after a minute..will start back up but run rough...i held it at 5k for a min and the smoke got real thickbut then i turned it off for a few mins (radiator fan came on when it was off) and when i turned it back on and revved it the smoke was not there... i am hoping there is just water in the baffles. this problem is defiantly heat related as it happened 3 times and only when the bike hit a certain temp...anything else i should be looking for?
on a good not before it started to smoke i took a little ride around the parking lot..tap the throttle twice and scared my selfi believe the ZG1000 has ample power to move me around
S!
LinkBack URL
About LinkBacks
