Old 10-06-2008   #1 (permalink)
AlexP1289
Made It To Second Gear
AlexP1289's Avatar
Default 1983 kz550m ltd shaft
Ok this started yesterday, basicly what is happening is when i go to take off in first gear it will some times stall and other times i can get her rollin and go where i want. She idles fine revs fine and rides fine i just lose power trying to take off standing still. Right now im running 93 octane in her, also throttle response isn't that great but its fine, any ideas?
AlexP1289 is offline   Reply With Quote
Old 10-06-2008   #2 (permalink)
Ericthejet
Forensic Bug Splatter Analyst
Ericthejet's Avatar
So, in goes the clutch, and you punch down on the shifter and she stalls?
Other than that, shifting is fine? If yes, clutch cable out of adjustment or clutch worn out and has gotten very grabby or contams. in the oil.
Now when you say "lose power" do you mean stalling and engine no loner running or do you mean when you start to move an apply throttle she is falling on her face having a hard time taking gas?
Gasoline is a non issue unless it's diesel. In cooler weather run the less expensive fuel unless you start to hear some pinging.
1984 Ninja 900 (A1)
To make it go faster I need to add more lightness!
Ericthejet is offline   Reply With Quote
Old 10-06-2008   #3 (permalink)
AlexP1289
AlexP1289's Avatar
When i start to move an apply throttle she falls on her face and has a hard time taking gas. I also changed the clutch lever that could be it right the adjustment could be off.
Old 10-06-2008   #4 (permalink)
AlexP1289
AlexP1289's Avatar
I have a clymer manual and am going to adjust the clutch cable to those specs.
Old 10-06-2008   #5 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
I don't think the "falling on it face" is coming from a clutch adjustment issue. Have you checked throttle response? Get the engine warm and at idle, then blip the throttle hard and see how the engine responds. See if it hesitates or dies from that. If it responds well, let it idle for a minute or 2 and try again.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 10-06-2008   #6 (permalink)
Ericthejet
Ericthejet's Avatar
These issues started once you had changed the clutch lever?
1984 Ninja 900 (A1)
Old 10-06-2008   #7 (permalink)
AlexP1289
AlexP1289's Avatar
yep just adjusted it and now it doesn't die as mutch but still hesitates a bit.
Old 10-06-2008   #8 (permalink)
Bob Myers1
Machinest for Sale/Rent
Bob Myers1's Avatar
sound's like the dreaded "confusing of terminology syndrome" here. Is it hesitating because you let the clutch out with not enough rpms, or does it fall on its face after you have taken your hand off the lever and it is fully engaged and pulling? What does it do if you are riding along and crack the throttle fully open? If it tries to die down and then stutter and start pulling, try it with the choke just slightly on, if it improves then you are starving for fuel, if it makes no difference then you are running too rich.
My 98 VN 800, my wife's 95VN800a
Myers Machine
Lexington, Ky
859-253-2259
Bob Myers1 is offline   Reply With Quote
Old 10-06-2008   #9 (permalink)
Zammy
Cruising In Fourth Gear
Zammy's Avatar
It's a common mistake to think higher octane gas helps in any way . It does not. All it does is allow you to run higher compression by SLOWING down the burn process , preventing detonation . THAT'S all it does. You actually get better performance by running the lowest octane that doesn't ping in your engine.
Zammy is offline   Reply With Quote
New guy, new bike, several questions! 87handmedown Vintage Motorcyle Info 122 07-30-2008 05:05 AM
1983 KZ750-F1 Shaft Firing issues ryanlong1 Vintage Motorcyle Info 3 07-08-2008 02:07 PM
1500 Classic Shaft Drive Bike Question chuck1 Kawasaki Cruisers 24 04-04-2008 05:56 PM
1983 KZ1100 L shaft drive speedometer jat307 Vintage Motorcyle Info 4 03-28-2007 10:54 PM
Shaft Drive vs Belt Drive vs Chain Drive Easyrider32 Kawasaki Cruisers 25 03-16-2007 06:22 PM
