Old 10-06-2008   #1 (permalink)
Texwing
Default z1 900 with 16 rear wheel and no centerstand??
The 1974 Z1 900 I just brought home has a 16 inch rear wheel with a new Dunlop, looks good but not original, and the bike has had the centerstand removed. I was about to get one from ebay, but then i realized that the centerstand might not work right (ie real hard to get it up on the centerstand) due to the lower profile of the wheel (i think its lower). Does anyone know, are centerstands removed because they do not work well with the non stock tire and wheel? thanks for the advice.
Texwing is offline   Reply With Quote
Old 10-06-2008   #2 (permalink)
Nessism
Third Gear And Gaining
Centerstand is a good thing. Even if it's hard to get the bike up on it, you can do it when necessary.
Nessism is offline   Reply With Quote
Old 10-06-2008   #3 (permalink)
Jeff.saunders
Obsessed by Z1's
Jeff.saunders's Avatar
Send a message via AIM to Jeff.saunders
Many stands get removed when 4-1 exhausts get fitted. Ground clearance is an issue, but I suspect your bike now has a 4-1 on it.
jeff@z1enterprises.com 1973 turbo'd Z1, 1973 stock Z1
www.z1enterprises.com
Jeff.saunders is offline   Reply With Quote
Old 10-06-2008   #4 (permalink)
Texwing
That would be correct, a relatively new 4 into 1 set up was on the bike when I got it. Does that mean that the centerstand will no longer fit or operate? the 4 into 1 in a "vance and hines" model or something like that, looks new.
Old 10-06-2008   #5 (permalink)
Jeff.saunders
Obsessed by Z1's
With the 16" rear wheel and a 4-1 you may have problems with ground clearance. Much depends on the exhaust system on the bike. If it is a V&H pipe, then you can use a stand - However, if you fitted a center stand, you'll need to fabricate a bracket to stop the stand hitting the chain.
What many owners do is keep the stand in the garage, fit it when changing rear tires or chains.
Old 10-06-2008   #6 (permalink)
techy
Can't find time to ride
techy's Avatar
My 73 Z1 has 16" rear with Hooker 4 to 1 and centerstand. No problems.
techy is offline   Reply With Quote
Old 10-07-2008   #7 (permalink)
Texwing
OK! I can fab brackets and i really do want a centerstand-what years will fit, and be correct-for my 74 Z1? I really appreciate the help.
Old 10-07-2008   #8 (permalink)
Jeff.saunders
Obsessed by Z1's
1973-1980 900 & 1000's.
Ground clearance - while you won't scrape the stand in a straight line, pushing hard around corners will scrape it - that's what you have to be careful of....
Old 10-07-2008   #9 (permalink)
coppertales
Uncle Bob's Love Child
Default I laced a 16 inch rim...
to my Z1 back in the 70's. There was no difference in the diameter of the 16 inch tire and the stock tire, just fatter. The ride was much smoother and the tire lasted twice as long too. There was a clearance problem with the chain guard though. No problem with the center stand.....chris3
coppertales is offline   Reply With Quote
Old 10-15-2008   #10 (permalink)
Texwing
I have been spotting centerstands on ebay rights and left, but oddly none seem to have the mounting hardware with them. Am I going to have a tough time rounding up the mounting parts and bushings, or is this pretty easy stuff to come by? thanks in advance.
