Let the good times roll!
I have a 1984 KZ550 LTD.Last winter I just added Sta-Bil to a full tank of gas,went for a 10 min ride,and drained the bowls on the carbs(no gas shut off).Pulled the plugs and gave the cylinders a shot of fogging spray.
Just wondering if this is the best way to store the fuel system for the winter. Or should I run the bike untill it runs out of fuel then drain any gas left in the bowls? Thanks........
'84 KZ550 LTD |
Forensic Bug Splatter Analyst
Full tank, fuel stabilizer mixed thru as mentioned, drain bowls, fogging oil, tire psi to max, cover muffler outlets with a bag and elastics, battery on a tender.
I would add a bit of gas line antifreeze (water remover) to the tank as well.
1984 Ninja 900 (A1) To make it go faster I need to add more lightness! |
Hey, you live in Ottawa! I was there for 20 years up to last July.
Which end of town? Do you have a battery tender? Best thing in the world for storage of the battery as you just hook it up and leave it in the bike.
#4 (permalink) |
Way Too Much Free Time
If you can block the bike so both wheels are not touching the pavement/garage floor. This will reduce the chance of creating a flat spot on the tires. Some 2x4's cut to fit under the engine works nicely for this.
Mike Folks |
#8 (permalink) |
Learning...
I found this webpage about a week ago and thought it would be a good guide to go by:
Winter Storage Guide for Motorcycles |
| Winterizing? | CruiseRider | Kawasaki Cruisers | 3 | 12-09-2007 08:41 AM |
| Winterizing my Ninja? | XR* | Kawasaki Streetbikes/Sportbikes | 4 | 10-24-2006 01:56 PM |
| Winterizing? | MatSox | Kawasaki Cruisers | 28 | 11-15-2005 01:10 PM |
| Sad Question RE: Winterizing | TMac | Kawasaki Cruisers | 26 | 10-12-2005 08:01 PM |
| Winterizing | MsPooma | Kawasaki Cruisers | 11 | 08-18-2005 11:04 AM |
