Old 10-07-2008   #1 (permalink)
clc
Default 1982 kz 1000 speedo question
I have an 82 kz 1000 j model. It has a non working electric speedo on it. I want to change it out to a cable driven speedo. Can I use the cable drive from the front wheel of any kz 1000? Or is there a kit for changing the over to cable driven?
Thanks for any help.
clc is offline   Reply With Quote
Old 10-07-2008   #2 (permalink)
coppertales
Uncle Bob's Love Child
Default Check your wires...
from the front wheel sensor to the speedo around the fork boot. That is where the wires get flexed the most and they might break. I have had the wires break on two of my 82 models. I have given thought to installing a mechanical speedo but I need to see the wheels side by side to see if they can be used.....chris3
coppertales is offline   Reply With Quote
Old 10-07-2008   #3 (permalink)
elr658
Motorcycling's Dr. House
elr658's Avatar
KZ1000M CSR has a cable driven speedo.
1982 Kawasaki KZ1000R1 #658
1980 Kawasaki KZ750H1 LTD
www.myspace.com/79cb750f
Old 10-08-2008   #4 (permalink)
clc
Thanks for the help
Who has replaced the bars on a CSR or LTD hsiafreak Vintage Motorcyle Info 23 04-29-2008 05:43 PM
Speedo hub prob. Replace or repair?? Trial'n'Error The Mechanics Corner 9 07-06-2007 07:48 PM
mule 1000 carb. question tradguy1 Kawasaki ATV and Mule 8 04-19-2007 05:17 PM
New ME880 tires and speedo pat0021 Kawasaki Cruisers 4 04-17-2007 04:46 PM
Suzuki - 1982 GS550 speedometer and buying question Stuart Main Lobby 3 06-01-2004 04:41 PM
