Old 10-08-2008   #1 (permalink)
slimmyt
slimmyt's Avatar
Default Correct piston ring installation kz750
I am putting new rings in my 82 kz750 ltd and like a dummy took all the old rings off of all the pistons before I started to install the new rings and now I don't know which of the top 2 rings goes in which groove. One of my upper rings is squared on the edges and the other is beveled on the piston side. Which one goes where and does the bevel go up or down?
thank you for your help
slimmyt is offline   Reply With Quote
Old 10-09-2008   #2 (permalink)
Alizard
The Cruising Gunsmith
On a 750 Twin:
The top ring has no bevels (no up or down direction)
the second ring has a beveled lip that goes downward.
The third ring is the wide oil ring, no up or down.
Alizard is offline   Reply With Quote
Old 10-09-2008   #3 (permalink)
slimmyt
slimmyt's Avatar
Thanks a bunch. You guys on here are awesome!
Piston Ring Installation Question? Spectre750 The Mechanics Corner 7 02-29-2008 08:53 PM
750 Twin Piston Ring Compatible? Alizard The Mechanics Corner 0 11-21-2007 11:12 PM
How do you do your piston and ring break in? iracekx Kawasaki Motocross and Offroad 5 09-21-2007 03:15 PM
Piston install/break in/jetting info HERE! >>> Lakeshore Kawasaki Motocross and Offroad 0 09-15-2006 01:05 PM
single ring wiseco piston davidonmars Kawasaki Motocross and Offroad 3 05-28-2006 10:14 PM
