Old 10-09-2008   #1 (permalink)
ratvespa
Turtle Wax Taster
ratvespa's Avatar
Default is it possible to adjust the ign timing on a 82 KZ1100B?
I pulled off my timing cover, and saw no slots, neither my clymer manual or the factory manual say anything about adjusting it.
I need to retard it a bit, due to the spark knock Im getting at higher load and revs, mostly due to the increase in compression. The only thing Im thinking of is putting it on my rotory table on my mill and making the mounting screw holes into slots so I can move it a bit. has anyone tried this?
ratvespa is offline   Reply With Quote
Old 10-11-2008   #2 (permalink)
ssrsonny
Third Gear And Gaining
you can slot the holes in the ignition plate os you can retard the timing.if you take the pickups off of the plate to do it make sure you put the magnets back on the same way they came off.if you flip either of them over it will not run on 2 cylinders.i have slotted a lot of them in the past.
ssrsonny is offline   Reply With Quote
1999 Ninja 250 timing chain adjust. lexluther The Mechanics Corner 10 05-20-2007 10:59 PM
96 zx7r keep burning ign. fuse??? minisiu Kawasaki Streetbikes/Sportbikes 1 04-23-2007 02:12 AM
Timing and point gap Rx7TyreBurna Vintage Motorcyle Info 3 06-28-2006 09:32 AM
Z1-900 Timing Chain Connecting Link? Tuning Info? bstanz1 The Mechanics Corner 2 01-09-2004 07:10 PM
