Old 10-28-2008   #1 (permalink)
rjd4949
California 79SR
rjd4949's Avatar
Default Internal Cleaning - Oil Change / '79 KZ650SR
Got my carbs dialed in (rebuilt them after a good cleaning including ultra-sound). Bike is purring. Still much more work to do - before now, hasn't been running for at least 10 yrs. I was thinking that I should change the oil with an inexpensive, but high quality oil (and maybe a cleaning additive), let that run thru for awhile (about 1/2 hour at hi-idle), then drain that off before putting in the Kawasaki brand 20-50 and the new filter. That way, any crud that doesn't drain off with the original oil, may come out on the first run-thru.
God idea? bad idea? Induce clutch slippage, maybe?
Your thoughts?
rjd4949 is offline   Reply With Quote
Old 10-28-2008   #2 (permalink)
rstnick
Can't find time to ride
rstnick's Avatar
Sea foam is made to do just that.
Vid
pics
http://www.kz650.info/
rstnick is offline   Reply With Quote
Old 10-28-2008   #3 (permalink)
StarGate
StarGate's Avatar
I used Seafoam and ran it about 100 miles with it in then, changed oil/filter.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
StarGate is online now   Reply With Quote
Old 10-28-2008   #4 (permalink)
Alizard
The Cruising Gunsmith
Seafoam is very good. You should be aware that after 10 years your oil pan (and everybody else's) will have a sludge layer in the bottom that is pretty much there to stay until you take the pan off and scrub it. Gravity always drops the particles down and forms a sludge layer on the pan that running and flushing can't get rid of. Never took an oil pan off that didn't have some.
Alizard is offline   Reply With Quote
Old 10-28-2008   #5 (permalink)
MFolks
Needs A Real Job
MFolks's Avatar
If you plan on running at a fast idle for 1/2 hour a very good idea is to get a large fan and keep it on the fastest speed it has. You need a cooling air flow to prevent overheating/seizing of the engine.
Mike Folks
MFolks is online now   Reply With Quote
Old 10-29-2008   #6 (permalink)
rjd4949
California 79SR
rjd4949's Avatar
Picked up the Seafoam tonight. Good advice on the oil pan. Didn't occur to me, but makes sense. I'll pull that and clean it.
Thanks, gang
Old 10-29-2008   #7 (permalink)
W-P Bill
Crazed Zed-head
W-P Bill's Avatar
+1 for Sea Foam.
You can only be young once, but you can be immature forever!
W-P Bill is offline   Reply With Quote
Old 10-29-2008   #8 (permalink)
RichLockyer
RichLockyer's Avatar
+1... SeaFoam and Castrol GTX.
Won't have any clutch issues with the Castrol.
- Rich
2006 1600 Ultra-Classic
Patriot Guard Rider
first oil change..... sheesh Natsack Kawasaki Streetbikes/Sportbikes 34 03-30-2009 09:19 PM
in the mail - Vulcan 2000 Oil Level Check Procedure Spok Kawasaki Cruisers 22 11-05-2008 12:19 PM
Loss of tanker deal to French/Germans BikerBeagle Off Topic 66 07-18-2008 11:45 AM
Time to change the oil... Speedracr Kawasaki Cruisers 6 09-01-2006 01:27 PM
How to change oil on 99 ninja 500R mixery2k The Mechanics Corner 8 01-22-2004 07:49 PM
