Old 10-30-2008   #1 (permalink)
bhanse
Question What year Kawasaki Motor?
I have a 1982 Kaw 1000 LTD according to the frame VIN. Problem started when I found out I had a 1980 swing arm (2 small needle bearings each side) Then I bought needle valve assy under LTD p/n but are different then what I have in the carbs now. Engine number is...KZT00JE034321. Would really appreciate some help.....thanks bruce
bhanse is offline   Reply With Quote
Old 10-31-2008   #2 (permalink)
ssrsonny
Clutch Cadet
the j in the number makes it sound like the right motor.maybe someone put different carbs on it.are they diaphragm carbs?
ssrsonny is offline   Reply With Quote
Old 10-31-2008   #3 (permalink)
bhanse
Under the top cover is a rubber diaphram/with a needle in the center and a plastic circular wheel covering the needle with a long spring holding the circular wheel and needle in place. The cap fits over the spring holding it down. Hope that helps.....found out the motor is an 82 J model
Old 10-31-2008   #4 (permalink)
elr658
Eddie Lawson is God!
elr658's Avatar
All of the motors put in the J,K,M,P,R were all stamped with J serial numbers.
1982 Kawasaki KZ1000R1 #658
1983 Honda CB1100F Blue.
www.myspace.com/79cb750f
Old 10-31-2008   #5 (permalink)
bhanse
Well I Talked to a Kawasaki mechanic w/30 years working on Kaws...I gave him my engine serial number ....he got back w/me and said I had a 82 j model motor....this is what I gave him....KZT00JE034231.... so maybe I don't have a J motor in my bike?......bruce
Old 11-01-2008   #6 (permalink)
ssrsonny
Clutch Cadet
yes you have a j-model motor.the easiest way to tell is the j-moel motors did not have a kick starter.
Old 11-01-2008   #7 (permalink)
elr658
elr658's Avatar
Yeah, and a twisted crank. Oh wait, that was the 81s.
Old 11-23-2008   #8 (permalink)
ssrsonny
Clutch Cadet
yeah lots of twisted cranks in the 81's.
Old 11-23-2008   #9 (permalink)
ssrsonny
Clutch Cadet
sounds like the parts guy may have looked up the wrong parts.were the needle and seats he orderd threaded or press in?yours should use press in with a o-ring around the seat.
Old 11-24-2008   #10 (permalink)
bhanse
Both the ones in the carbs and the ones I bought from Z1 are pressed in with an "o" ring around the lwr portion of the valve. Btw the p/n is 16030-1016 for the float valves. The last 4 digets of the carbs is 1358 which according to the Kawasaki microfish for the carbs is the correct p/n for my bike.....I don't know what's going on......Ssooo I sent the carbs to "Wiredgeorge" in Texas to have them FIX them.....sent him one of the new float valve assy also ......so hopefully he'll tell me WHAT IN THE WORLD IS GOING ON with these float assys. thanks for the help.....I do really appreciate all of it......bruce
Kawasaki can make you sick. Uncle Bob Off Topic 24 01-15-2009 03:00 PM
year of motor? kkkingklick Kawasaki Streetbikes/Sportbikes 1 08-14-2008 02:51 PM
does my z1r have the org motor? marksgpz750trbo Vintage Motorcyle Info 13 11-22-2007 10:48 PM
Kawasaki customer Mid-Ohio track day $99 extremelean Main Lobby 0 07-27-2006 09:24 PM
I don't own a Kawasaki, but my 5 year old does. theroyz71 Main Lobby 4 12-16-2003 01:29 PM
