my ohm readings between the three yellow wires are within the manuals specs, but the three all are shorted to ground. the bike maintains the battery at 12.25 volts when on open road. The 4pin connector to the stator was melted, when I went to solder the leads and eliminate the plastic connector, as the kz1300 club website recommends. My Kuryakyn battery monitor never sees green.
Is there an explanation as to why the bike charges at all, and how are they grounded now. My hope is to find the ground condition and fix it, and hold out that the stator must be still ok. Perhaps the wires are pinched and making contact with the case cover?
Could the stator be OK and the leads test grounded short, and the bike still charge at all?
thanks for the info. jim
LinkBack URL
About LinkBacks
