I searched, and found this thread (this is really a great site):
http://www.kawasakimotorcycle.org/fo...low-tubes.html I want a bit of advice from a "second opinion" though - I have one carb that is definately leaking via the overflow tube as in the thread above - I can fill the bowl halfway with fuel (when it is off the carb), and it slowly drips out the overflow. Now the advice: will JB weld work as suggested in the link and be impervious to fuel? Have others had this kind of leak and repaired it in a similar way? Thanks!
'04 ZZR 250, '78 KZ650 |
Vintage bike addict
I used JB Weld on a car gas tank years ago. Something bounced up under the car and punched about a 1/8" hole. It never leaked for the few years I owned it after that. If use of JB Weld concerns you there are similar products specifically made for fuel tank repair. Just be certain to give your product of choice full curing time.
82 KZ750LTD, 84 Virago 700, 85 Vulcan 700.78 KZ750 twin,82 KZ650, 77 KZ650, 75 CB200T,Vince |
#4 (permalink) | |
FNG
#5 (permalink) | |
Thanks for the advice, though. I have done a throrough carb disassembly and clean (soaked, blown out, etc.).
#7 (permalink) |
Vintage bike addict
Acid core flux would work best but yes. Just be careful to not flow too much solder. You might plug the tube.
#8 (permalink) | |
Nice! I'll try that this weekend with some small electronics-type flux-core solder. Thanks for the help!
| carb. setting for factory 1986 zx600 with vance and hines header and pipe??? | jwiley | Kawasaki Streetbikes/Sportbikes | 2 | 10-28-2008 05:15 PM |
| Carb Issues - I think | medic29 | The Mechanics Corner | 23 | 09-22-2008 08:33 AM |
| Pipe for a 1982 LTD 1000 ??? | dannyg40 | Vintage Motorcyle Info | 1 | 04-24-2008 07:07 PM |
| KZ750R1 Carb Leaking | stocksj | Vintage Motorcyle Info | 1 | 04-18-2008 11:18 AM |
| Leaking Carb! | doors1024 | Kawasaki Streetbikes/Sportbikes | 4 | 04-25-2007 10:40 PM |
