Old 11-22-2008   #1 (permalink)
gpzrocker
Clutch Cadet
Default Starting when REALLY cold
Maybe some people have no issues starting their old bike when it is really cold. Good for ya. I'm not so lucky. So my old bike mechanic showed me what to do a year or three ago, and it has worked, so you might want to try it.
After a night where it hit 17 and might have gotten up to 20-25 when it was time to ride, I unhooked the trickle, choked, set the vacuum operated petcock to prime, switch on, starter would just spin. After about 4 tries, I pulled the seat, lifted the tank, and stuffed a towel down in the airbox hole to REALLY make the mixture rich.
And it fired right off. Pulled the rag immediately, and I was good to go. Honestly was kind of hoped it wouldn't work, cause it was really cold to not have a real windshield (my fairing blows air right at my neck), but all in all it was a good time.
This happened before and after the amazing cleaning I had done on the carbs: actually on both sets, I have ran two sets in the last few years. And after a head rebuild this year. I think it is just an old bike thing, maybe just mine, but my mechanic jumped on that fix way to fast to have not tried it before.
Get in a jamb, try it. I'm sure someone will tell me a tech thing like " when it is that cold, the valves/rings are not sealing properly" or some such. Yep, a 24 year old bike w/ 36K+ miles, even with new valve seals, sometimes needs a little help.
And if it doesn't work, you could always realize that it is just too cold, and try to get your group to do a Christmas in July setup. When it is slightly warmer. Or take the car, and snicker at the joker whose knees are playing taps on the tank.
gpzrocker is online now   Reply With Quote
Old 11-23-2008   #2 (permalink)
antiq
Vintage bike addict
antiq's Avatar
Yep old sometimes needs help to wake. Car truck or bike.
82 KZ750LTD, 84 Virago 700, 85 Vulcan 700.78 KZ750 twin,82 KZ650, 77 KZ650, 75 CB200T,Vince
antiq is offline   Reply With Quote
Old 11-23-2008   #3 (permalink)
MBB
MBB's Avatar
My 91 Kawi Zephyr has this problem,from 92 on they were fitted with carb heaters,I dont know how effective they are?
MBB is offline   Reply With Quote
Old 11-24-2008   #4 (permalink)
gpzrocker
Clutch Cadet
Now that is interesting: I wonder if my favorite parts source (ZR-7) has them....
Old 11-24-2008   #5 (permalink)
antiq
Vintage bike addict
antiq's Avatar
You could always do what we did way back when on the cars. Put a trouble light near the engine and cover with a blanket to keep the heat in for an hour or so then start normally.
Old 11-25-2008   #6 (permalink)
gpzrocker
Clutch Cadet
Good call.
Why does my old bike have trouble starting in the cold? Ninja Noob Kawasaki Streetbikes/Sportbikes 12 11-19-2007 05:23 PM
ZX9R 2001 misfire when cold Ninja900Ben The Mechanics Corner 5 08-28-2007 03:23 PM
220 Bayou cold starting problem lexluther Kawasaki ATV and Mule 0 02-21-2006 09:20 PM
KVF 360 cold weather starting mike360 Kawasaki ATV and Mule 4 10-18-2005 12:02 PM
Bike Not Starting Taz The Mechanics Corner 11 01-03-2005 06:33 AM
