Thib
HI all,
I am looking at an old 78 Z1R but the person has lost the keys, is there someway to have a new one cut with the serial number, vin number? Any recommendations would be appreciated, Thanks in advance Mark |
Needs A Real Job
If you have no key to use as a master to cut from, the only recourse is to replace the ignition switch with a new one. Unfortunatly the other lock will need changing also(tank,helmet locks,and seat lock). Try the local dealer for a new set of locks first.
There are several places on the net that supposedly can cut new keys using the key number but want $25.00 each for a key.
Mike Folks |
FNG
if one of the helmet locks are open there should be a key number on it u might need to take the lock of to get a better look or u can take off the seat lock thats where i got my key # from it should be stamped in the side. ( if this guy will let u do any of this that is ) and if you cannot do any of the above Mfolks suggestion is the other way to go. order a new ignition and deal with no helmet locks or seat lock. gass tank should be fine though u can usually juts use any key that fits for the stock tank cover.
#4 (permalink) |
nu2kawi
![]() Join Date: Sep 2007
Is the bike able to be started, so you know how it runs. Has a clean title for it. You should be able to find a replacement switch that would work or at least modify, if a key can't be made for it.
07, Z1000 01, XVS1100LC Yam cust. |
#5 (permalink) |
Vintage bike addict
If you get the bike just take the ignition to a good locksmith. He can make a key to fit. A little pricey but still cheaper than replacing all the locks.
82 KZ750LTD, 84 Virago 700, 85 Vulcan 700.78 KZ750 twin,82 KZ650, 77 KZ650, 75 CB200T,Vince |
| RE: Make extra keys! | 99Saki500 | What I learned today | 39 | 2 Weeks Ago 06:26 AM |
| Best place to get spake keys cut | flanman | Kawasaki Cruisers | 21 | 08-22-2009 03:17 PM |
| Back Compartment Ate My Keys | dam05 | New Rider Forum | 1 | 07-25-2008 11:17 PM |
| Lost Keys, but I have my Key Code -- Who can make a new key? | Red Barchetta | Kawasaki Cruisers | 8 | 04-06-2008 12:00 AM |
| Leatherlyke saddlebags with no keys...help!! | Utah Motorcyclist | Kawasaki Cruisers | 6 | 01-04-2008 09:54 PM |
