Old 11-27-2008   #1 (permalink)
Mike Drew
Default Where to get '82 GPz1100 front rotors?
Hi guys,
While cleaning up my fork tube pitting problem, I noticed that my front rotors look pretty thrashed. They are deeply grooved and uneven, and my micrometer tells me they are a bit under the 4.5 mm min thickness.
So, where does one obtain replacement rotors, other than E-bay?
I see an outfit on E-bay selling various used KZ1000 rotors, a pair from a 1982, and another pair from a 1993 police KZ1000. I seem to recall that the brake rotors changed between the '81 and '82 GPz1100. Would '82 KZ1000 rotors be the same? What about the '93 police rotors?
Anyone? Anyone? Bueller?
1982 GPz1100, 1983 KZ1000R Eddie Lawson Replica, 1986 ZX600R Ninja
Mike Drew is offline   Reply With Quote
Old 11-27-2008   #3 (permalink)
Mike Drew
Just found them listed here, at
Buy Honda Parts,Suzuki Parts,Yamaha Parts,Kawasaki Parts,Arctic Cat Parts,Sea Doo Parts,Can Am Parts
They are pretty proud of them--the asking price is $359.49 each!
I later found them at another site (actually, duh, I found the sticky at the top of the forum page and have been surfing around those sites) for $308 and change. A little better, but still....
Okay, so anybody have a good source that won't cost an arm and a leg?
And equally important, can anybody confirm that the KZ1000J, police bike etc. all use the same rotors as the GPz? If so, then E-bay is calling....
Thanks!
Old 11-27-2008   #4 (permalink)
gpzrocker
Clutch Cadet
http://www.kawasaki.com/Home/Home.aspx
Go to owner info, parts diagrams, type in your info. IIRC, when you find the rotor, you click on it and the description comes up. There is a place (I think it is a question mark) that you can click on and it shows all models that came with this same part number.
My GPZ is a mismash of alot of Kawasaki's due to this. I think my rear brake disc is a front disc off of another gpz, and the pads were labeled for a 500 Vulcan.
Although it sounds like you are a prime canidate for a whole front clip change, like off of anything newer. It might be cheaper.
gpzrocker is online now   Reply With Quote
Old 11-27-2008   #5 (permalink)
doebag
Norfolk,England
doebag's Avatar
Z1100A1-A3 shaft. Front disc 236 mm, rear disc 236 mm.
GPz B1 twin shock model. Front disc = 236 mm, rear disc = 236 mm
GPz B2 twin shock model. Front disc = 246 mm, rear disc = 236 mm
Z1000J. Front disc 236 mm, rear disc 236 mm
GPz 1100A1-3. Front disc 246 mm, rear disc 236 mm.
However, the unitrack discs look different in design/style to the B2 ones. Worth a closer look to see if the mountings are the same though.
EDIT. ABOVE SIZES ARE WRONG EVEN THOUGH THEY ARE GIVEN BY KAWASAKI IN THEIR TECH. DETAILS
'Dying a'int much of a living boy'
Outlaw Josey Wales
doebag is offline   Reply With Quote
Old 11-27-2008   #6 (permalink)
Mike Drew
Damn. Using the Kawasaki website tool (great tip, thanks!), it reveals that this part number is only used on the '82 GPz1100 and the '82 and '83 Eddie Lawson Replica.
The question now before the court is, are there other rotors that have a different part number but the same physical characteristics? The post above gives some physical dimensions for various bikes, but it's far from complete. I'd love to know what size the police bikes use, for example, as they are still plentiful in the junkyards.
Thanks to all for your help so far!
Old 11-27-2008   #7 (permalink)
ssrsonny
Clutch Cadet
i have some.they are in good condition.you have a p.m.
ssrsonny is offline   Reply With Quote
Old 12-01-2008   #8 (permalink)
Mike Drew
Hi guys,
Looks like Sonny (above) struck out--apparently what he had were smaller rotors. I just roughly measured the ones on my bikes (both '82 GPz1100 and '83 ELR), and they are far larger than the post above would have you believe; they are about 11 inches across. It's difficult to measure them exactly on the bike of course, but the numbers listed above are definitely way wrong--246 mm is only about 9.5 inches.
So, I'm now stuck back at square one. Still looking for '82 GPz or '82-83 ELR front rotors. Anybody??
Thanks!
Old 12-01-2008   #9 (permalink)
ssrsonny
Clutch Cadet
Default rotors
dont give up yet.i had the right o.d. but not sure on the bolt pattern.will check tomorrow.thanks.sonny
Old 12-02-2008   #10 (permalink)
ssrsonny
Clutch Cadet
i have struck out so far.if i find some i will let you know.i know a guy that had a 82 gpz that he drag raced.i think he took one of the rotors off.ihe is supposed to call me tonight.
Old 12-03-2008   #11 (permalink)
doebag
Norfolk,England
doebag's Avatar
Originally Posted by Mike Drew View Post
Hi guys,
Thanks!
Mike, I have to apologise. All the dimensions I quoted are from Kawasaki sales brochures and technical data. It seems they are way out.!!!
I have physically measured the discs on my Z1100A and they are 270mm [approx 10.5" ] front and back.
So I guess the B1 discs are the same, don't know about the B2 then.
Sorry again I will edit my original answer to high light the error.
Outlaw Josey Wales
Old 12-03-2008   #12 (permalink)
ssrsonny
Clutch Cadet
i have tried all of my sources and have struck out.i will keep looking but if anyone else has them help him out.i have one rotor for a 83 gpz but the other rotor was taken off years ago when the guy was dragracing the bike.the 83 will bolt up and is the right size but it has a different pattern where they drilled the holes i the rotor.thanks.sonny
Old 12-03-2008   #13 (permalink)
MFolks
Needs A Real Job
MFolks's Avatar
Have you tried these two websites? www.z-power.co.uk and www.zpower.com.au
Mike Folks
MFolks is online now   Reply With Quote
Old 12-04-2008   #14 (permalink)
gpzrocker
Clutch Cadet
I'm still thinking that you should go this route: if it is hard to find parts now, how bad will it be if you decide to keep the bike?
Old 12-05-2008   #15 (permalink)
MFolks
Needs A Real Job
MFolks's Avatar
The EBC website has: front brake pads # FA68 and FA68 HH (high friction)
Front rotors #MD4038LS (left side), #MD4038RS (right side)
Rear brake pads # FA68 and FA68 HH (high friction)
Rear rotors #MD4054
Mike Folks
Old 12-06-2008   #16 (permalink)
elr658
Eddie Lawson is God!
elr658's Avatar
No you can NOT have mine. Ha ha. I'll bet the cop bike rotors work.
1982 Kawasaki KZ1000R1 #658
1983 Honda CB1100F Blue.
www.myspace.com/79cb750f
Old 12-17-2008   #17 (permalink)
Mike Drew
Rear rotors #MD4054
That's great to know! I'll definitely go that route if I can't find any decent used stock rotors.
Thanks very much!
I Need Help lifting front of '92 ZX750 Big Willy1 Kawasaki Streetbikes/Sportbikes 9 10-23-2008 03:57 PM
Kz550m1 front tire AlexP1289 Vintage Motorcyle Info 2 08-30-2008 02:57 PM
HELP!! Putting 1977kz spoke rims on a 1982 KZ1000 LTD, need brake rotors for swap FULLMONTIE Vintage Motorcyle Info 2 12-30-2007 06:09 PM
New rear tire with old stock front? Villaven Kawasaki Streetbikes/Sportbikes 8 03-06-2007 02:18 PM
06 636 Front Axle Question jninja The Mechanics Corner 1 02-25-2007 03:25 AM
