Please help ID my carbi
+ Reply to Thread
Results 1 to 5 of 5
Thread: Please help ID my carbi
  1. #1
    Join Date
    Jan 2009
    Posts
    5
    Default Please help ID my carbi
    Hi people, hoping someone can help a newbie with a identity crisis
    I have recently purchased a Z250c from a friend.
    I have noticed it has a fuel leak from around the bowl seal which appears to have been made from silicon.
    I took the carbi bowl with me to my local Kawasaki dealer but they say it's not the original carbi and so have no idea what seal i need.
    The engine runs fine with this carbi, apart from the fuel leaking slightly, so i'd like to stay with what i have but need to know what it is or what it came from so i can get a kit for it.
    Any advice is most welcomed.
    The only markings i can find on it are; KEIHIN japan, and the number 26 circled.
    Inside the bowl is stamped; OK(quality cont. i figure), F circled followed by -2-3
    I have these pics too
    Thanks
    Steve
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Made It To Second Gear BTK Beginner brokenrod's Avatar
    Join Date
    Mar 2008
    Location
    northern Illinois
    Posts
    91
    I'm not sure if i'm allowed to post a link to another forum, but Wiredgeorge would certainly know wiredgeorge motorcycle carburetors - Vintage Japanese Motorcycle Carburetor Sales, Rebuilding and Restoration - Home He is a master with the KZ and other older carbs
    I started out with nothing, and still have most of it.
  4. #3
    KZ Addicted (needs Help) BTK Expert Andy the gringo's Avatar
    Join Date
    Apr 2006
    Location
    Akron, Ohio
    Posts
    498
    I don't know where you're from but since you have a Z and not a KZ I'm guessing it's not the US. That looks to be a carb that Kaw used on the KZ200's as well as the KLT200 3 wheelers. The part number for the gasket you need is 11009-1028 that's the good news, the bad news is that it shows as being discontinued. It is possible though that a dealer may have one laying around in inventory somewhere and if you give them a part number they are more likely to be willing to check for it.
    As to stopping your fuel leak, try cleaning up the brass float valve with a Q-tip dipped in some Mother's mag polish. It goes a bit faster if you chuck the Q-tip in a drill. Just keep polishing until the Q-tips no longer turn black and the seat gets nice and shiney then spray away any Mothers with some carb cleaner.
    80 Z-1 Classic
    84 GPZ1100
    77&79 1000 LTD
    76 KZ900
    KZ750 X 2
    KZ650 X 7
    KZ550 X3
    305 CSR
  5. #4
    Join Date
    Jan 2009
    Posts
    5
    Cheers guys, im from Aussie land so that explains the Z code.
    I spoke to a guy who suggested i try a sealer called Stag jointing paste, its safe for fuels and oils etc. so i gave it a go.
    Had it running today and no leaks so far..fingers crossed.
    Thanks again
    Steve
  6. #5
    No Significant Other BTK Expert MFolks's Avatar
    Join Date
    Jul 2008
    Location
    Springfield Mo
    Posts
    10,117
    Mike Folks
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. carbi diagram??oil leak?
    By tube18 in forum Kawasaki Motocross and Offroad
    Last Post: 03-28-2006, 08:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
