82 KZ1100 charging issue
+ Reply to Thread
Results 1 to 2 of 2
Thread: 82 KZ1100 charging issue
  1. #1
    Join Date
    Aug 2007
    Location
    Crestview, FL
    Posts
    17
    Default 82 KZ1100 charging issue
    Before I loaded it on the trailer and moved it to Florida I had it in the shop for a carb re-jet and some electrical problems. New battery and stator installed. It was sort of charging but just barely 12 volts. I think he said 11.7
    Anyway, it was running great while it ran. I took it out for an 8 mile ride to test it out. First 2 miles it ran like a new bike. Took off from the light and a little hesitation but nothing bad. Cruised steady at 55mph then sputtered. Gave it some more rpms and it cleared up. Next stop it sputtered a lot but I got it going. Last 2 miles were very bad but it did ok as long as the rpms were kept up. It died in the driveway. Battery was dead too.
    I'm going to get a new rectifier. Is there anything else it
    could it be besides the rectifier? The stator was a new unit
    Bryan
    USAF retired
    1982 KZ1100 A2 Shaft drive
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Riding Vintage BTK Intermediate Killbert's Avatar
    Join Date
    Aug 2008
    Posts
    206
    Well you are going to have to isolate the problems most apparent first. Once you repair the charging problem, the electrical system can no longer be blamed for these problems, and you can move on to something else. My initial response was that you needed a good carb cleaning, but if your circuit voltage was only at 10 volts or so, your coils wouldn't have had the required voltage to fire a good spark. One problem at a time. Good luck on the fix. Keep us posted.
    Kellyn
    Riding Vintage.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Weird power issue
    By CaseLogic in forum Main Lobby
    Last Post: 08-10-2008, 08:04 PM
  2. Oil Leak, Charging problem
    By bcampos in forum Kawasaki Cruisers
    Last Post: 06-14-2007, 01:23 AM
  3. How does the charging system work...anyone?
    By sublimobile in forum The Mechanics Corner
    Last Post: 02-08-2007, 03:52 PM
  4. Replies: 0
    Last Post: 10-15-2006, 11:04 AM
  5. 1986 Vulcan 700 charging issue
    By Pender in forum Kawasaki Cruisers
    Last Post: 12-22-2004, 07:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
