brake upgrades for 81 GPz1100
+ Reply to Thread
Results 1 to 3 of 3
Thread: brake upgrades for 81 GPz1100
  1. #1
    Still On The Kickstand BTK Beginner red and black's Avatar
    Join Date
    Jan 2009
    Location
    NJ
    Posts
    47
    Default brake upgrades for 81 GPz1100
    i have an 81 GPz1100 with completely shot brakes. this might be a good time to upgrade to something newer/better. anyone done any swaps to newer rear caliper or master, or newer front calipers? is it possible....the rear caliper mount looks pretty clunky compared to newer bikes.
    the prices for new master cylinders are nuts....there has to be a better way.
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Top Gear Full Throttle BTK Expert ratvespa's Avatar
    Join Date
    Feb 2007
    Location
    Las Vegas NV
    Posts
    303
    you are much better off doing a complete front end swap than just the brakes. Something from a newer bike. Guy I know has a old suz GS1000 and just swaped some forks/wheels/brakes from a newer sport bike onto it. and it pretty much bolted up with little modification
  4. #3
    Sit speling cheker BTK Expert
    Join Date
    Dec 2007
    Location
    Western NC
    Posts
    437
    I just installed a 04 250 Ninja rear master cylinder and it bolted right up. On my 84 GPZ750. Looking at what I was when I was shopping, I have little doubt that it would work for you. And it is a much better unit.
    I have no doubt that more modern units can be found for the front. I would look at pictures on ebay and try to find someone to give you the bolt to bolt measurements.
    --Light bulb over head--
    Brake pads have a fairly good cross reference setup. I'd start with a pad cross reference, see what that gives. I used that to get some EN450 rear pads for my bike for like $5.
    I haven't personally looked to see what calipers would cross, but you have me wondering. I do know they need to be tokico, and I can see alot of the period bikes running the same brakes. As a matter of fact, on most, the rear caliper and disc is the same as front, so that info could help.
    Good luck, and keep us posted.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Bike-a-holics quick and easy brake bleeding guide
    By Spok in forum Projects and "How To" Write Ups
    Last Post: 02-04-2013, 06:42 PM
  2. front brake system
    By sweeted in forum Main Lobby
    Last Post: 11-23-2008, 08:56 AM
  3. brake adjustment
    By das fisch in forum Kawasaki ATV and Mule
    Last Post: 09-18-2008, 01:59 PM
  4. any brake upgrades for 93 zx7?
    By 1.8tbeout in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 03-18-2008, 01:29 PM
  5. GPZ1100 Brake Pad Removal
    By Steve P in forum Vintage Motorcyle Info
    Last Post: 01-30-2008, 05:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
