front signal wiring routing on 81 GPz1100
+ Reply to Thread
Results 1 to 3 of 3
Thread: front signal wiring routing on 81 GPz1100
  1. #1
    Still On The Kickstand BTK Beginner red and black's Avatar
    Join Date
    Jan 2009
    Location
    NJ
    Posts
    47
    Default front signal wiring routing on 81 GPz1100
    on my recently purchased 1981 GPz, the PO removed all of the wiring for the front indicators....it was aimed towards the drag track. i see no evidence of cut/trimmed wires, missing connectors, etc.
    can anyone tell me where the wires for the turn signals originates? is it part of the headlight wiring harness? If you can have a look at your bike and let me know, much thnx!
    Sourland Mountains of NJ
    81 GPz550
    81 GPz1100
    99 ZG1000
    Some cool cars, too
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    No Significant Other BTK Expert MFolks's Avatar
    Join Date
    Jul 2008
    Location
    Springfield Mo
    Posts
    10,117
    Remove the headlight and look inside the housing. The connections should be there for the turn signals. I have an 82 GPZ1100 B2 so I'm using my factory motorcycle service manual wiring diagram here.
    The left front turn signal wiring goes like this:
    1. The gray wire plugs into the green wire bullet connector.
    2. The blue wire plugs into the blue wire bullet connector
    3. The black wire with yellow stripe plugs into the same color bullet connector.
    The right front turn signal wiring goes like this:
    1. The gray wire plugs into the gray wire bullet connector
    2. The blue wire plugs into the blue wire bulet connector
    3. The black wire with yellow strips plugs into the same color bullet connector.
    This bike has running lights in the front turn signals for added visibility so make sure the replacement signals have the correct soclets in them.
    I believe the bulbs are 1157(same as the rear brake lights) in the front with 1156 in the rear signals.
    Mike Folks
  4. #3
    Join Date
    Jan 2009
    Location
    NJ
    Posts
    47
    Mike-
    thnx! the rears were unplugged from the barrel connectors, so I hope the fronts were also disconnected, and not hacked up. I will pull the headlight and take a look.
    81 GPz550
    81 GPz1100
    99 ZG1000
    Some cool cars, too
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Turn signal mod w/ pics
    By rbentnail in forum Projects and "How To" Write Ups
    Last Post: 10-03-2007, 08:30 AM
  2. Corroded Turn Signal?
    By kobender in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 10-11-2005, 02:08 PM
  3. front signal light for 2006 zx-10r?
    By ninjavin6r in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 10-10-2005, 10:40 AM
  4. Replacing your stock front turn signals - Mean Streak
    By SleekStreak in forum Kawasaki Cruisers
    Last Post: 08-18-2005, 08:57 PM
  5. Front brake problems
    By placidfemme in forum The Mechanics Corner
    Last Post: 05-11-2005, 09:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
