Needs A Real Job
If the stock coils ohm measurements are close to the buick coils and the mounting will work I don't see why not. Most if not all electrical systems have a plus and minus factored in for interchangeability.
Mike Folks |
I have not heard of using a car coil in place of a bike one but they all do the same thing electrically, step up the voltage. The only thing with a car component is that it might not be nearly as light or compact as one designed for a bike. I replace my stock coils with ones made by Dyna Coil. In the process I was able to remove the ballast resistor altogether which freed up a little room in the triangle beneath the fuel tank. Anyplace you can bring in better technology without having to do major modifications is good. THe Dyna coils were a direct bolt in without any mods to the electrical system, besides the removal of the ballast resistor.
#6 (permalink) |
Use Nology coils, perfect replacement, very little modding needed, and twice the zap of stock!!! Been using them for 2 years, and no complaints! Can also throw out the ballast resistor too. The ProFire PFC-30D (3.0 Ohm Systems) is our baby
#9 (permalink) |
I can vouch for the fact that the twin coils off a V6 Mitsubishi work without any problems, Im using the ones from a twin turbo engine and they fit in the original places with a tiny modification and give a massive spark.
Two coils on top and one underneath, the only drawback is that the lower coil has to be removed to get the valve cover off. |
#10 (permalink) |
itching to ride
Back in the 70s I read an article in cycle where they were installing automotive coils on bikes and wiring a resistor in to keep from burning up the points. They were strapping them to the frame downtubes which gave a somewhat ugly look.
I even put a pair on our RD 250. Two coils two hose clamps and a ballast resistor. Ugly but effective. ![]()
1983 gpz 750 .....the wait is over |
#11 (permalink) |
Here's the latest. I have been so busy this year that I'm just now getting back to working on this bike. The previous owner burned out part of the igniter soe I am using a GM ignition module to bypass the bad portion of the igniter. Can't afford the $800.00 igniter. Will post whatever happens.
#12 (permalink) |
Needs A Real Job
There a rider over at KZrider.com - Home that has designed a similar ignition circuit using two GM electronic modules. I'd imagine that in your case three would be neded because you have 6 cylinders instead of 4.
Are your pick up(pulsing coils) 120 degrees apart?
Mike Folks |
#14 (permalink) | |
This space for rent
| 76 KZ900 Rejetting | akkz | Vintage Motorcyle Info | 13 | 07-09-2009 04:49 PM |
| Coils heating up? | kzcrazy750 | Vintage Motorcyle Info | 14 | 10-07-2008 02:19 PM |
| day one of my restoration project - 78 KZ1000 | johnnycrash | Vintage Motorcyle Info | 12 | 10-01-2008 12:22 PM |
| 81 KZ750 LTD fuel problem | michaelcycle | The Mechanics Corner | 6 | 09-30-2008 01:05 AM |
| 1980 KZ650 Coils | 80KAW650 | Vintage Motorcyle Info | 4 | 05-08-2008 10:36 AM |
