Old 02-17-2009   #1 (permalink)
jmh249
Justin Hallenbeck
Default Questions About My 81 Kz650
I originally posted this in the regular forum last night but someone suggested i post in here as well....
Hi I just picked up a KZ650 and the motor turns over but won't start. There's new spark plugs and a new battery, any ideas on what i might need to do. Someone suggested the "coils" but if anyone could elaborate on that point that'd be great also.
I got suggestions that the carbs needed cleaning, they're now clean but it still won't start. Someone said if i pull a plug and ground one to the case then turn it over, if it sparks my coils are good, but if not it could be them. any other ideas? this is my first project so i'm very open to any and every idea that might help.
jmh249 is offline   Reply With Quote
Old 02-17-2009   #2 (permalink)
herk
bustedfeet
herk's Avatar
My bike is the 81 KZ650-CSR.
When the bike is cold, you should have to use the Choke to start it.
The carbs are "now clean"? How so? How bad were they?
If the bodies weren't soaked overnite or something, then the passages may still be gummed up or clogged.
Fresh fuel - tank & carbs. Verify fuel flow to the carbs.
Clean airbox & air filter. Good airbox ducts - not hard or cracked.
Good or new spark plugs - B7ES & properly gapped.
Redo the spark plug wire connections - the wires unscrew from the coils.
Good battery - properly filled & charged. Verify the voltage.
Coils - check the primary & secondary resistance.
Other stuff: Good carb holders w good vacuum nipple caps. Make sure the air injection system tubing isn't cracked. Lubricate the timing advancer. Redo any electrical connections at every opportunity: the connections become poor over time from oxidation. Compression check. Valve clearance check sometime soon.
herk is offline   Reply With Quote
Old 02-17-2009   #3 (permalink)
jmh249
Justin Hallenbeck
Lots of great info, thanks so much.
Old 02-18-2009   #4 (permalink)
rstnick
Can't find time to ride
rstnick's Avatar
Congrats on finding a kz650!
Check out the kz650info site as well.
Specific info on the 650s.
There's also a Haynes Service Manual download in the forum section that could be of some help if you don't already have a service manual.
KZ650.INFO
Vid
pics
http://www.kz650.info/
rstnick is offline   Reply With Quote
Old 02-18-2009   #5 (permalink)
jmh249
Justin Hallenbeck
Thanks rstnick, i saw the pics of your KZ, looks awesome. Could you link me to the service manual download? Thats awesome theres one, i was gonna go to this salvage yard that has tons of motorcycle manuals and see if i could find one... but itd be nice to just download it....
Old 02-20-2009   #6 (permalink)
vinnye
Turtle Wax Taster
vinnye's Avatar
The only thing I would add to the above advice would be to change the plug leads and caps - they may be the original ones!
You couls by some 7mm auto cable and make your own leads - its cheaper.
UK - South Yorkshire
vinnye is offline   Reply With Quote
Old 02-28-2009   #7 (permalink)
jmh249
Justin Hallenbeck
Hey I wanted to put the "pod" style air filters on my bike but i'm not sure what size to get for the 650. Any help? thanksss
Old 02-28-2009   #8 (permalink)
rstnick
rstnick's Avatar
Here's a link to the Haynes manual download:
Haynes repair manual for 1976 to 1980 KZ650
I can't remember what size pods to get. I had them on for years, but did have some issues with wind gusts bogging the bike down, and rain was a pain.
Jetting will have to be changed anytime you make intake or exhaust changes.
Most find the stock air box the most reliable, myself included.
There are some pods listed on ebay for the kz650s. This may help you with the sizing info.
Vid
pics
Old 3 Weeks Ago   #9 (permalink)
jamel88
did you ever get your bike going because am having the same problem with my 81 kawasaki kz650
jamel88 is offline   Reply With Quote
Old 3 Weeks Ago   #10 (permalink)
kawpaul
itching to ride
kawpaul's Avatar
Maybe try posting a new thread in here or the mechanics section. Lots of knowlegable people on this site who are more than willing to help out.
1983 gpz 750 .....the wait is over
kawpaul is offline   Reply With Quote
77 KZ650 Carb questions. emoellm Vintage Motorcyle Info 8 05-04-2009 05:16 PM
questions about my 1981 kz650 jmh249 Main Lobby 5 02-17-2009 03:34 PM
Questions about KZ650 mods...see pic! Lee_S Vintage Motorcyle Info 7 11-23-2008 06:37 AM
1979 KZ650 - Carb rebuild and tuning questions DigitalFusion Vintage Motorcyle Info 6 03-29-2008 10:26 PM
82 KZ650 Questions latemodel2003 Vintage Motorcyle Info 9 07-17-2006 09:30 AM
