Go Back   Kawasaki Motorcycle Forums > Photo Gallery > Want to show off your ride?
Old 05-14-2008   #21 (permalink)
Michael600r
Ninja tomato farmer
Michael600r's Avatar
That is one perfect machine.
Ninja 600R
Ninja500R, sold
Michael600r is offline   Reply With Quote
Old 05-14-2008   #22 (permalink)
CheeseHeadNinja
Winter sucks!
CheeseHeadNinja's Avatar
Originally Posted by Skunkwurcx View Post
Thanks CHN....the oil filter on mine is a cartridge type, meaning the filter element material is not wrapped in tin like the one on most cars. It fits inside the engine on the bottom towards the frt of the engine. There is a round, ribbed plate on the bottom of the crank case which has a bolt in it's center. Remove that bolt, and the plate will drop to allow the filter to be removed. There is a secondary bolt too, which allows the oil from the filter housing to be drained before you remove the filter. This is not the main oil drain though...there is another one just to one side of the filter location. As for oil....that depends on the air temperatures that can be expected while running a particular weight oil - I use 10W-40 as the temps here never get too blisteringly hot.
It's not hard to change the oil in it, the biggest issue is getting the bike high enough to get a pan under it and still have some room to manouver, and there may be a clearance issue with the pipe. Get the engine warm first is all I would say.
Ok thanks man! Sounds a little messy to change that filter. Hopefully I can figure it out. How hard is it to find replacement filters? Could I just go into a Kawi shop and get one ordered easily?
Thanks again! Needless to say, the one I'm helping on doesn't look nearly as good as yours!
CheeseHeadNinja is offline   Reply With Quote
Old 05-14-2008   #23 (permalink)
CTRider
TV Guru
CTRider's Avatar
That was a common filter type for bikes of that vintage. My Honda has pretty much the same design. They should be available at any Kawi shop - though it may be a special order. In my case, the Honda shop near me always has a few in stock.
You can also get them online. They'll run anywhere from around $5-$8.
If they're the same style, then they're a paper filter, which means you have to be more vigilant about changing them. However, there are sites that offer adapters to convert the bolt-on mount to a spin-on type.
1983 Honda CB550
About Me
Answers to your Gadget Questions
Gadget Forum
CTRider is offline   Reply With Quote
Old 05-14-2008   #24 (permalink)
A2rider
Banned
A2rider's Avatar
I like changing the oil on my KZ. It's a fairly painless process, you can see everything you need to get to, and need no special tools. Yeah, you're going to get dirty, but that's life.
A2rider is offline   Reply With Quote
Old 05-14-2008   #25 (permalink)
CheeseHeadNinja
Winter sucks!
Well.. yeah I know I'll get dirty. I just thought I'd be messy trying to get the filter out cuz of the way the exhaust pipes seem to go under the bike. Eh. The oil will burn off the pipes
Old 05-14-2008   #26 (permalink)
A2rider
Banned
A2rider's Avatar
Put a rag over the pipes. And I don't mean your wife, either.
Old 05-14-2008   #27 (permalink)
Skunkwurcx
Top Gear Full Throttle
Skunkwurcx's Avatar
It's no real biggy to change it, when it's all typed out like that it seems to be, but in practice, it's not. One other thing though that bears mentioning. The main bolt up through the ribbed round plate extends all the way up and in through the filter. Inside, between the bottom of the plate, and the bottom of the filter, there is a large, about 1"Ø flat washer and a spring, at least on mine there is. I mention this because if the pipe is in the way, it may be neccesary to hold the ribbed plate in place till the bolt is removed, letting everything drop out once the bolt is clear. You may have to fish for them in the drain pan, or just drain the oil outta the pan till you get them...whatever. The order they go back in is with the spring on the bottom and the washer on top of the spring between the spring and the filter. Again, more fiddlesome in writing than in practice. As for the filter, I have been getting real Kawi ones from the dealer....I think Emgo makes 'em too, but I prefer to stick with the Kawi ones.
As for oil on the pipe, you're right....it burns off !!!
Also, thanks again Cheese for the compliment on my bike
1977 KZ1000 LTD now Z1000A
2007 Vulcan 900 Custom
2002 ZX9R
Skunkwurcx is offline   Reply With Quote
Old 05-14-2008   #28 (permalink)
mbigica
Bridal Boutique Manager
mbigica's Avatar
That's one nice KZ. May take on a project with my son with that or something similar some day.
mbigica is offline   Reply With Quote
Old 05-14-2008   #29 (permalink)
c_law23
Missy Peregrym's #1 fan!
c_law23's Avatar
Send a message via Yahoo to c_law23
i love it, that thing is sweet...nicely done
Chris
VROC #24810
Black 2007 900 Custom (sold)
http://s131.photobucket.com/albums/p...0900%20Custom/
c_law23 is offline   Reply With Quote
Old 05-14-2008   #30 (permalink)
Surftechuser
Surfer
Surftechuser's Avatar
Excellent job, that bike really looks nice! I bet it hauls!
2006 Vulcan 2000
Surftechuser is offline   Reply With Quote
Old 05-14-2008   #31 (permalink)
Nate
KZ Kool!
Nate's Avatar
Check Walmart. You'll likely find one there.
"Riding is the reward for time spent wrenching."
"Wrenching is the result of time spent riding!"
KZ650 SR
Nate is offline   Reply With Quote
Old 05-14-2008   #32 (permalink)
AWM
Motorhead
AWM's Avatar
Shweeet!!!!!!!!!
AWM is offline   Reply With Quote
Old 05-15-2008   #33 (permalink)
CTRider
TV Guru
CTRider's Avatar
Unlikely. These are bolt-on filters, not spin on.
1983 Honda CB550
About Me
Gadget Forum
Old 05-15-2008   #34 (permalink)
Andy the gringo
KZ Addicted (needs Help)
Andy the gringo's Avatar
Originally Posted by hayward6 View Post
You get extra points for the state of the art test gas tank
True but you have to deduct points for the fuel filter being installed backwards. Andrew you can regain those lost points by sending me all your take off stuff. I recently bought a 77 1000 LTD and I could make good use of all that stuff now taking up valuable space in your garage.
Your painter knows his stuff, that's some fine looking work. The paint scheme reminds me of one used on a KZ400 about 1975 IIRC.
80 Z-1 Classic
77 1000 LTD
76 KZ900-Sold to Denmark
KZ750 X 2
KZ650 X 7
KZ550 X 4
305 CSR X 2
Andy the gringo is offline   Reply With Quote
Old 05-15-2008   #35 (permalink)
Nate
KZ Kool!
Nate's Avatar
Are they different than the one used on the KZ650 which are internal? I can buy them all day long at the local Wally World.
KZ650 SR
Old 05-15-2008   #36 (permalink)
ispeed77
RIP Deron Harden :-(
ispeed77's Avatar
Send a message via AIM to ispeed77 Send a message via Yahoo to ispeed77
looking good Andrew, nice job
In loving memory of Deron Harden, forever in our thoughts :-(
ispeed77 is offline   Reply With Quote
Old 05-15-2008   #37 (permalink)
Skunkwurcx
Skunkwurcx's Avatar
LoL....Andy, well you could have had those take off parts, but I'm afraid you're wrong about the filter.....it is in correctly....how do I know this ? because I did have it in wrong until I noticed the little arrow with "flow" written inside it ....I get my points back I get my points back
Andy the gringo;1111047]Your painter knows his stuff, that's some fine looking work. The paint scheme reminds me of one used on a KZ400 about 1975 IIRC.
The paint scheme is based on a '75 Z1-B 900 for the tank, and on the '74 Z1-A for the tail. I chose what I feel is the best of those two years....I changed the colour in the top tank stripe from black to charcoal....Tony certainly knows how to spray, that's for sure. Aside from a few specks of dust, there isn't a ripple or a wave in the paint....the pics don't do the colour justice
2002 ZX9R
Old 05-15-2008   #38 (permalink)
ImpactG
Perpetual Motion
ImpactG's Avatar
Wow here too! That is a very, very nice job and machine!
ImpactG
2004 V2K
Proud member of Julie's Avatar Cleavage Club (JACC#3)
ImpactG is offline   Reply With Quote
Old 05-15-2008   #39 (permalink)
A2rider
Banned
A2rider's Avatar
I think they moved it from main lobby. It was competing with the helmet/small cc debates.
Old 05-15-2008   #40 (permalink)
ispeed77
ispeed77's Avatar
yeah, that was me, but not because it was competing, just trying to clean up the main lobby a bit.
