LinkBack | Thread Tools |
#41 (permalink) |
KZ Kool!
![]() Join Date: Oct 2004
Older regulators (such as those found on KZ models) seem to be more susceptible to being burned out by jump starting. I suspect that they don't have much reverse voltage protection built in and even a fairly low (more than a few volts over nominal battery voltage) level reverse voltage spike can kill them. Even though the battery in a car does a good job of suppressing the alternator's spikes that get past the rectifiers, a failing alternator could put a few tens of volts of A/C on the car's DC system. This is probably enough to damage the older regulators.
Jumping a 12 volt bike from a car or pickup with a 12v system while its engine is off should pose no problem other than the usual precautions.
"Riding is the reward for time spent wrenching." "Wrenching is the result of time spent riding!" KZ650 SR |
#46 (permalink) | |
Ridden like a Ford!
2001 Black Mustang GT 2005 Phantom Silver 1500 Classic Royal Purple synthetic oil in both |
#47 (permalink) | |
yellow doesn't corner wel
Darrell Ignorance is a disease my friend. You should rid yourself of it. |
#48 (permalink) | |
Thanks to all Veterans!!!
Location: PGR Member #7955 O'Fallon, Illinois (Near St. Louis)
RIP Deron Harden. :-( You are truely missed. |
#50 (permalink) |
topcatflyer
![]() Join Date: Jun 2006
voltage with out apms safe. voltage with amps will kill electrical stuff and by the way you also. electrical circuts are designed to run on specific amperage. over amperage is like over pressure on a pipe to much and bang. voltage by its self 30,000 to 50,000 volts won't kill you if its not being pushed by amperage. i.e. coil. jumping from a source that is pushing to much amperage can damage
#51 (permalink) | |
#52 (permalink) |
Enough already! It is basic Ohm's Law... If you have 12 volts and 1 ohm of circuit resistance, it will draw 12 amps. Doesn't matter if you have a 12 million amp supply... the circuit will ONLY draw 12 amps. You can't PUSH more amps into a circuit than it can draw!
The problems occur if the jump battery is connected incorrectly (ie: positive to negative, negative to positive.) Just a momentary contact will cause problems with cars as well as motorcycles. Can blow fuses, fuse links, and electronics. |
#53 (permalink) | |
Turtle Wax Taster
2005 Biege 1600 Classic I just can not get rid of that taste of turtle wax! |
#54 (permalink) | |
#55 (permalink) |
Fastback
I just jump started my 81' CSR last weekend with a friends F-150. It wouldn't start while the truck was off so we turned the truck on. Worked fine. I suspect his truck batt was pretty weak. I knew it would work because I also had the opportunity to jump start my old Suzuki GS1000 with my wife's Grand Am and later, a wall charger. Yeah it was plugged into a wall socket. I checked the cross voltage while it was on and it was the same as a vehicle's 14V A/C. I don't see why it wouldn't be the same. It's less expensive to keep it all the same. Otherwise we'd all have the much better 24V systems in our vehicles.
#56 (permalink) | |
The two bikes loads connected in parallel would have a combined resistance of 1.6 ohms. Assuming a 12 volt supply, they would, combined, draw 7.5 amps or 3.75 amps each. |
#57 (permalink) | |
#58 (permalink) | |
(You know, of course, I'm only playing, and I already know the answers to these.)
RIP Deron Harden. :-( You are truely missed. Last edited by likearock4x4 : 08-21-2006 at 10:06 PM. |
#60 (permalink) |
Neuromancer Lvl 13
Just gotta throw my two cents in. I had to get my bike jump started about 5 times in a row from cars. All had their engines running, no issues with the bike. If there is a problem, it's not showing up, knock on wood!
The only valid censorship of ideas is the right of people not to listen. ~Tommy Smothers |
| Thread | Thread Starter | |||
