Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > What I learned today
Old 03-27-2007   #1 (permalink)
Crazy Dave
Crazy Dave's Avatar
Default Fan assembly
The other day, I finally ran my VN750 long enough to warm the engine and engage the cooling fan. Trouble was I heard something whirring, but I saw that the blades weren't turning. I consulted my trusty VN750 repair manual, and saw the problem lay with the fan assembly. Because Kawasaki doesn't break the fan assembly into smaller parts, I thought I was going to be stuck buying the whole assembly for $460 (MSRP). I felt a little better when I found it on RonAyers.com for $361. Then I thought I could do a little better buying it used. I stumbled across RiderParts.com to search for used parts, and going that route, I got price quotes for $60, $90, and $100.
In the meantime, I removed the radiator cover and the radiator, and disconnected the fan assembly to see how bad it was. When the plastic blades fell off the spindle (or whatever it's called), I surmised that maybe an old epoxy job had given out.
To make sure it was just the blades, I connected the fan assembly to the wires that run to the horn (the connectors are the same). I honked the horn, and sure enough, everything (minus the plastic blades) worked fine.
I gave up the search for a fan assembly, choosing instead to replace the blades. I found aluminum blades on muzzy.com. Just $50 (includes s&h). Sure beats $460!
Crazy Dave
Falls Church, VA
1995 Vulcan 750
Crazy Dave is offline   Reply With Quote
Old 03-30-2007   #2 (permalink)
CTRider
TV Guru
CTRider's Avatar
Now, go treat yourself to something worth $410. You earned it...
1983 Honda CB550
About Me
Answers to your Gadget Questions
Gadget Forum
CTRider is online now   Reply With Quote
Patriots Fan? bdutton Off Topic 3 01-26-2007 05:37 PM
Fan Run Times - VN800A StanB Kawasaki Cruisers 8 07-31-2006 12:17 PM
Radiator Fan FrankC Kawasaki ATV and Mule 7 05-06-2006 10:29 AM
750 vulcan cooling fan ? blk90s13 The Mechanics Corner 1 06-05-2005 11:26 AM
Cooling Fan 97 1500 BUBF bob917 Accessory Swap Meet 0 03-05-2004 04:26 PM
