Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > What I learned today
Old 07-11-2008   #21 (permalink)
textbookninja
Finally Got Into First Gear
textbookninja's Avatar
Yeah, that's the problem with the speed checkers, they seem to always be in 25-35 mph zones. Hard to check your highway calibration in a neighborhood.
And yes, I do speed up a bit when approaching them to watch the numbers change.
textbookninja is offline   Reply With Quote
Old 07-11-2008   #22 (permalink)
Jaysin
Made It To Second Gear
Jaysin's Avatar
Does anyone know the reason for the difference between indicated and actual speed? I feel it has somthing to do with the size of the wheels or somthing like that.
Jaysin is offline   Reply With Quote
Old 07-11-2008   #23 (permalink)
soc_monki
Wants better weather!
soc_monki's Avatar
well, if you increased or decreased the size of the wheel, but got a tire profile that kept the wheel/tire the same diameter it wouldnt affect it. get a bigger or smaller tire than that and yes, speed would be affected. same as with a car!
the speedometer can also be affected by the gearing...go up or down in teeth on the sprockets and your speedo will be off even more. im not sure how they do the speed readings on my bike, or most any bike actually! i might have to look that up...
2008 Lime Green ZX-6R DIY Fender Eliminator, Jumper Mod, Yoshi RS-5
My Musical Stuff
Lucian Scott
soc_monki is offline   Reply With Quote
Old 07-16-2008   #24 (permalink)
jsharp07
jsharp07's Avatar
Send a message via AIM to jsharp07
actually most bikes have the speedo cable run to the center of the front wheel. gearing wouldn't affect it. but changing tire size would.
jsharp07 is offline   Reply With Quote
Feeling Bad Granny Off Topic 7 02-11-2008 12:06 PM
Good news, bad news BigJohn Off Topic 0 11-01-2007 10:05 AM
Bad Day Granny Off Topic 6 10-24-2007 12:01 PM
Think you are having a bad day? BigJohn Off Topic 23 01-16-2006 09:35 PM
Minn. Trooper Writes 205 Mph Ticket rlovrin1 Off Topic 12 09-27-2004 08:51 PM
