Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > What I learned today
Old 07-01-2008   #1 (permalink)
gr8ride
Top Gear Full Throttle
gr8ride's Avatar
Default Cold Tires/Quick stopping = trouble
Cold tires and quick stop breaking do not mix very well. My stocker dunlops on my ninja 250 were cold this morning during my commute. I saw the light turn yellow and did not have time to throttle it through the light so I had to hit the brakes hard. So I hit the brakes and felt the rear tire go stiff and heard it sliding. It started to go to the left so I squeezed hard on the front brake and balanced with my legs then released the front brake and got back on it so I wouldn't lock it up.
I thought I was definitely going down as soon as my skid went left. I kept on the rear brake as long as I could maintain the skid in a direct line and let off at the end to gain balance. Getting on the front brake even more than I originally did, saved my bacon, it saved my skid and kept me upright.
07 Ninja 250R Silver- mucho mods....
06 CBR F4i Blue- Stock
Next: Ninja 636 or ZX6r Green!
gr8ride is offline   Reply With Quote
Old 07-01-2008   #2 (permalink)
cjp91068
Wants better weather!
cjp91068's Avatar
Then you went home and changed your underwear. LOL
I had a close call recently with my front brakes - so I know how scary it can be.
Chris
former 2008 Ninja 250R owner :-(
If I give you a cookie, will you go away?
cjp91068 is offline   Reply With Quote
Old 07-01-2008   #3 (permalink)
gr8ride
gr8ride's Avatar
The Rear brake skid was scary enough for me, I had to go out and practice my quick stops just to reassure myself.
I could not imagine skidding the front, that would scare the hell out of me.
Old 07-03-2008   #4 (permalink)
soc_monki
soc_monki's Avatar
its actually less risky to skid the front than it is to skid the rear. the reason is because the rear tire is about 80% of the stability in the bike. if that tire stops rotating, your stability is gone and the bike wants to fall over! if you skid the front you have a better chance of correcting the mistake as long as the rear tire is still rotating (as long as youre not leaned over...then its low-side time!)
just remember...the front brake is your best chance of stopping. in an emergency squeeze both levers (clutch/brake) and add in rear a little at a time. dont aggressively use the rear brake! with all that weight transferred to the front youll just lock it up that much easier. use sparingly and it can really help though.
and always use the rear brake in low speed manuvers...i barely touch the front if im under 10-15 MPH...engine braking does most of the work then anyways. if youre turning at low speed and have to hit the brakes use the rear...the front will just low-side you.
i have a link to a bunch of motorcycling articles that discuss this and other motorcycle related riding tips and "how bikes work" stuff. but im at my girls house and i dont have the link here. ill post it later its good reading!
2008 Lime Green ZX-6R DIY Fender Eliminator, Jumper Mod, Yoshi RS-5
My Musical Stuff
Lucian Scott
soc_monki is offline   Reply With Quote
Old 07-03-2008   #5 (permalink)
gr8ride
gr8ride's Avatar
Thanks, I appreciate the help. Most of the time riders just have to "figure it out" without help.
Old 07-03-2008   #6 (permalink)
soc_monki
soc_monki's Avatar
no problem man we should never learn alone...ive been reading as much as i can and learning as much as possible before i ride! you can never learn too much.
just be careful with the back brake...it can help a lot of times, but in times where you need to stop fast it can really mess you up if youre not careful!
one more tip...when on gravel or any type of loose surface use the back brake! with the reduced traction you could easily lock up the front and put the bike down. just go slow and use your feet as outriggers if need be...bikes and loose surfaces dont go well together. unless youre on a dirt bike...but thats a WHOLE 'nother ballgame!
My Musical Stuff
Lucian Scott
1980 KZ650 Cold Star Problems? transam32 Vintage Motorcyle Info 27 04-15-2008 08:39 PM
ZX9R 2001 misfire when cold Ninja900Ben The Mechanics Corner 5 08-28-2007 02:23 PM
Cold idle issue on 1500FI T-man The Mechanics Corner 10 11-09-2005 12:21 AM
2005 ninja electrical trouble heather Kawasaki Streetbikes/Sportbikes 4 08-02-2005 01:47 PM
1500 Classic Ignition Trouble hiway_dominator The Mechanics Corner 2 03-19-2004 10:25 PM
