Super Sherpa no spark - Kawasaki Motorcycle Forums
post #1 of 3 (permalink) Old 05-27-2019, 05:31 PM Thread Starter
Junior Member
2000 kl250 cranks but no spark or 12v at coil. I phoned out the wire from cdi to coil. It was good. Checked for power and ground at cdi. Had both. Checked fuses even with a test light on either side of the fuses. I ohmed out the kill switch is good. Bypassed kick stand and clutch switches. I bought a used “known good” cdi. Replaced coil and boot, stator, diode, and new battery. Still no spark.. I just took the harness off the bike and inspected. No problem found yet.. anyone have any advise?
B_mack22 is offline
Sponsored Links
Advertisement
post #2 of 3 (permalink) Old 07-11-2019, 05:15 PM
Junior Member
I too am having the same problem, can't figure out why my super Sherpa doesn't have any spark. Any help would be much appreciated!
StrangeTamer69 is offline
post #3 of 3 (permalink) Old 07-13-2019, 09:02 AM
Member
With all the work you have done it seems like an impossible situation. You did not however mention testing the key switch. If that checks out then I would go over each step to make sure you are testing correctly. Are you sure you correctly bypassed the safety switches? Are you 100% certain that the swapped CDI was actually good, ie did it come from a running bike and did the bike still run after you put it back?
WFO-KZ is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
