3010 must be choked to start - Kawasaki Motorcycle Forums
post #1 of 6 (permalink) Old 11-23-2010, 02:50 PM Thread Starter
Junior Member
Just purchased a used 07 3010. I have to choke it every time to start the engine, unless it is still warm. If I wait ten or fifteen minutes to start again, I have to choke it but it cranks right up. It was 80 degrees this past weekend and i still have to choke it. Is this normal? I've only owned a honda four wheeler in the past and it only needs choking if it is near freezing outside. I just want to know if this is normal or not. Thanks
morganfield is offline
Sponsored Links
Advertisement
post #2 of 6 (permalink) Old 11-23-2010, 10:19 PM
RCW
Senior Member
Re: 3010 must be choked to start
It is pretty much normal to have to use the choke below 60 degrees F, so I suspect you also have some gum build-up in the primary/pilot fuel circuit. Add a bottle of SeaFoam to the fuel tank and run it through. The starting should get a bit easier after the carburetor is clean.
It is part of living with EPA requirements and a carburetor. It can be fixed, but requires the pilot jets to be resized to a larger size.
If toys will get me in the door when it is time to go, I have it made!
RCW is offline
post #3 of 6 (permalink) Old 11-23-2010, 11:24 PM
Junior Member
I have a 2001 3010 and I have to choke it unless it has only been sitting for a few minutes, doesn't seem to matter if it's a 100 or 30 degrees. I have just recently enlarged the pilot jets, best thing I have ever done to the mule. (Thanks to RCW) but I still have to choke it if it sits for a length of time. No big deal though it starts right up.
John
jocat54 is offline
Sponsored Links
Advertisement
post #4 of 6 (permalink) Old 11-24-2010, 12:10 AM
Junior Member
Ditto for my '05 3010. It does not make any difference on the ambient temp, it always needs to be choked on the first startup, or after 1 hr of sitting, but runs fine after that.
Jay
torotoro is offline
post #5 of 6 (permalink) Old 11-24-2010, 03:47 AM
AK Cold Start Specialist
ivarraven's Avatar
I can't tell 'cause the warmest it's been for the past for months was 31 degrees! And I had to chain up to get up a hill because of ice rain!
I've just noticed that they tend to need a bit of richness to start the first time in a few hours.
By the way. make sure that you zip tie some of those brake lines out of the way.$)
ivarraven is offline
post #6 of 6 (permalink) Old 12-01-2010, 05:16 AM
Senior Member
if you're in a state that uses ethenol blend in their gas you may want to try using Stablizer for ethenol mixes. It's blue and is for marine use but here in NY I use it in everything and it seems to do the trick. Also I concur with RCW that the Sea Foam additive works great also.
MICKEYTKD is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
