2007 Mule 610 Rattle while driving - Kawasaki Motorcycle Forums
 2Likes
  • 1 Post By daweeve
  • 1 Post By imported_cookie_monster
post #1 of 8 (permalink) Old 04-01-2019, 04:51 PM Thread Starter
kpt
Junior Member
I bought my 2007 about two weeks ago. The past two days, when I get going at medium speed, there is a rattle coming from the underside. I can't identify the source, I put it on a jack, put it in hi and ran it. No noise at all. It seems to only happen when I'm rolling. Anyone have experience with this issue? I love the thing and want to take good care of it.
kpt is offline
Sponsored Links
Advertisement
post #2 of 8 (permalink) Old 04-05-2019, 11:58 AM
Junior Member
Is it 4x4? Sounds like the same thing that happened with my 2510 4x4 Mule which ended up being a loose driveshaft. My initial problem was worn splines on the front pinion gear that caused rattling at all speeds, which I ended up using red loctite to keep it permanently in place. After I did that, I had rattling at speeds above 10-15 mph which was caused by lateral movement of the driveshaft from moving the driveshaft (carrier bearing to front diff) too far forward on the pinion gear. Fixed that with a spacer on carrier bearing.
kpt likes this.
daweeve is offline
post #3 of 8 (permalink) Old 04-08-2019, 08:05 AM
Senior Member
Grab the propeller shaft and see if it will shake back & forth. If it does, the carrier bearing assembly is shot. They aren't rebuildable; replace only. When replacing it, make sure all the u-joints are phased properly.
kpt likes this.
imported_cookie_monster is offline
Sponsored Links
Advertisement
post #4 of 8 (permalink) Old 04-15-2019, 04:45 PM Thread Starter
kpt
Junior Member
Thanks Guys. I am finding some movement in the drive shaft. I did not realize it had a carrier bearing. I will check it out. I just got my service manual today.
kpt is offline
post #5 of 8 (permalink) Old 04-16-2019, 07:43 AM Thread Starter
kpt
Junior Member
Hi Imported. I do think my carrier bearing is shot. Thanks for the advice! Is it difficult to change? I bought an electronic copy of the shop manual, but it is not great. Thanks!
kpt is offline
post #6 of 8 (permalink) Old 04-16-2019, 04:18 PM Thread Starter
kpt
Junior Member
Actually, I was just under the Mule. The only loseness I can find is in the front propeller shaft. It seems to rattle where it slides into the U-joint that connects to the carrier bearing. I can find no slop in the carrier bearing or the U-Joints. Has anyone had this problem? Thanks.
kpt is offline
post #7 of 8 (permalink) Old 04-22-2019, 08:35 AM
Senior Member
Yes the yoke could be worn out, as could the shaft that it rides on.
Check the phasing of the u-joints while you're under it. If out of phase, it'll cause vibration and therefore a rattling....and abnormal wear.
post #8 of 8 (permalink) Old 04-22-2019, 11:28 AM Thread Starter
kpt
Junior Member
Thanks, Imported. I had the yoke out. The rubber boot was not in place. I injected some great into the splines and put the boot back in place. So far, the noise appears to be gone, but I have only driven it a couple of times. I will check the phasing of the u-joints, also.
kpt is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
