I have a 2002 Kawasaki Prairie 650 and have had trouble starting it. Typically this happens when it has sat for several months without riding it. A couple of weeks ago I tried to start it with no luck and started looking for the problem. I found out the fuel pump wasn't working and bought a new fuel pump from HighFlowFuel part #HFP-360KP-Prairie650. I did all of this before I pulled the fuel tank and removed the fuel pump. Yesterday I pulled the tank and fuel pump assembly out. The fuel pump assembly is completely rusted and a lot of rust is in the tank. The electronics are in bad shape and don't believe it could be working.
I need help finding the fuel pump assembly. What I am calling the assembly is the metal frame the pump and other items are mounted to (see Fuel Pump Assembly pic).
I also need the electronics that come mounted to the frame (see Fuel Pump Electronics pic) if they don't come with the fuel pump assembly.
Thank you for helping me out!
