Bayou 400 KLF shaft play - Kawasaki Motorcycle Forums
post #1 of 4 (permalink) Old 06-26-2019, 02:31 AM Thread Starter
Junior Member
Hi, I have a bayou KLF 400 4x4 Quad with a poorly engine. Camshaft completely wrecked, but Iíve found somewhere that can regrind and sort rockers to as new condition.
But Iíve encountered another issue, there seems to be quite a lot of play on the shaft the clutch is mounted on, end float rather. In the manual I have, it doesnít show any shims or specs on permissible end float. Is it quite normal to have visible end float?
Iím stripping the motor as if Iím spending quite a large sum on the top end, I want the bottom end in good condition too.
Will replace the whole oil pump too and fit a pressure gauge on the oil supply pipe to the top end just in case!
Cheers
Steve
Greenbloood is offline
Sponsored Links
Advertisement
post #2 of 4 (permalink) Old 06-27-2019, 08:22 AM
Senior Member
Well if the crankshaft itself is moving back & forth, either the bearings are bad or the crank is. But it's normal for the clutch drum to have some end float on the crankshaft if that's what you are speaking of.
imported_cookie_monster is offline
post #3 of 4 (permalink) Old 06-27-2019, 05:33 PM Thread Starter
Junior Member
I am not near the motor(itís at a friends) but is the clutch on the end of the crank shaft? What ever shaft itís on, thereís quite a bit of end float.
Steve
Sponsored Links
Advertisement
post #4 of 4 (permalink) Old 08-19-2019, 08:58 AM
Senior Member
Yep. Last time I did one, there was about 1/8" end float in the clutch drum. That's what I remembered anyway. It's been a while....and for good reason. Lot of KLF400 parts are no longer available from Kawasaki.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
