Mule 3010 Gas Governor - Page 4 - Kawasaki Motorcycle Forums
 2Likes
post #31 of 41 (permalink) Old 12-05-2011, 08:53 AM
Senior Member
Re: Mule 3010 Gas Governor
The EFI mules are electronically controlled by a STUPID dual butterfly throttle valve. One butterfly is mechanically controlled via cable. Then the other is totally electronically controlled by the ECU and it changes its position based on vechicle speed and engine RPM, among other things. so it more or less closes when the RPM gets to 3800 and/or vehicle speed reaches 25 mph give or take. I suppose someone 'could' invent a tuner which would let the max MPH be at an increased speed and the RPM be increased to ~4500 or so. But unfortunately that is the only way to bypass the governor on the EFI's is to do it electronically. Maybe someone could try a resistor in the speed sensor circuit?
imported_cookie_monster is offline
Sponsored Links
Advertisement
post #32 of 41 (permalink) Old 12-05-2011, 08:55 AM
Senior Member
Originally Posted by LIEPKE1844 View Post
.......and my jeep has a 5901 crate motor 9 over and a blower 1800 hp without the nitrous !!!!! i love to max everything out ,go fast !!!! boats .cars .motorcyles golf carts 4 wheeler's ,planes ,what ever has a motor on it !!1
I want to see pics of the jeep. And a dyno sheet.
post #33 of 41 (permalink) Old 12-05-2011, 12:44 PM
Junior Member
no one has answered my question, post#29
trex232 is offline
Sponsored Links
Advertisement
post #34 of 41 (permalink) Old 12-05-2011, 03:41 PM
Senior Member
Originally Posted by trex232 View Post
Will the motor still be govenered by doing this, will it over rev in low range
Yes the governor still works, although the engine speed is quite a bit higher in both low and high range. The governor works off of the transmission input shaft speed which is independent of the engine speed.
post #35 of 41 (permalink) Old 06-28-2012, 02:37 AM
Junior Member
I did this June 2012, and got 6 mph more on gps, cheapest mod I have ever done, cheers fuel man
zedsled1 is offline
post #36 of 41 (permalink) Old 10-01-2016, 03:18 AM
Junior Member
Originally Posted by Fuelman View Post
I got a request to see pics of the gov adjustments I have done. With this adjustment I was able to get about a 10MPH gain. Now my mule goes 38 MPH according to the GPS. Fairly simple adjustment, I drilled a new hole on the gov arm and moved the existing spring to the new hole, 3/4 of an inch. Made one adjustment to the idle screw to lower it so as not to grinds the gears while shifting.
I just did exactly as shown in the diagram and my mule 3010 trans 4x4 tops out at 29 mph on my gps on level ground, and I also run 26 inch tires with a 2" lift. Will a hole at 1" gain more speed??
MQBZAR is offline
post #37 of 41 (permalink) Old 12-25-2018, 05:14 PM
Junior Member
I know this is an older thread but i just picked up an 06 3010 and wanted to see the pics that you originally posted. The pics aren't coming up in this thread for me. Thanks
Edke6bnl likes this.
syclone01 is offline
post #38 of 41 (permalink) Old 12-26-2018, 09:01 AM
Junior Member
Edke6bnl's Avatar
can someone pass along the thumb nail pictures, I believe I now what is being done but a picture is worth you not what.
Kawasaki Mule 3010 2003
live in the High Desert of Southern California
Edke6bnl is offline
post #39 of 41 (permalink) Old 12-26-2018, 11:39 AM
Junior Member
Yes, pictures would be nice. Im looking for any help i can, my mule top speed is 16 MPH by gps and i dont think that is quite right.
brianlterrell is offline
post #40 of 41 (permalink) Old 04-15-2019, 06:14 PM
Junior Member
I realize this post is very old...but some of the only info I can find on the mule 3010 governor...I cannot see the pics unfortunately...
Any way to repost or send them to me??
TIA
mikeymike2018 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
