1600 CC Vulcan (Mean Streak) Rear Cylinder Spark Plug Fouling - Kawasaki Motorcycle Forums
post #1 of 9 (permalink) Old 08-07-2012, 02:27 PM Thread Starter
Boomer
Thumper Champ's Avatar
Our 2008 Mean Streak has the following symptoms: The rear cylinder right-side spark plug is extremely dark (significant buildup) and the remaining 3 spark plugs appear normal (insulator color, tip, etc.). This condition was first noticed at 5,000 miles. I changed all plugs (DPR6EA-9 with .036 gap), torqued the plugs and rechecked at 8,000 miles. Same indication. Cleaned the plug and rechecked at 13,000. Same indication. Here we are at 20,000 miles and this has become "normal" for this plug.
The dealer has checked the bike twice and found nothing out-of-spec. I've always run top-tier premium fuel (per the OEM Manual)......Shell, Mobile, BP, Chevron. The bike is not "lugged" and I ride one-up (180lb rider).
Question: has anyone experienced a two-plug-per-cylinder issue similar to the one I have tried to describe??? Thanks in advance.
Michael
'08 Meanie SE
Thumper Champ is offline
Sponsored Links
Advertisement
post #2 of 9 (permalink) Old 08-08-2012, 10:37 AM
Senior Member
Re: 1600 CC Vulcan (Mean Streak) Rear Cylinder Spark Plug Fouling
Try swapping the coils with each other to see if the problem moves.
sfair is offline
post #3 of 9 (permalink) Old 08-12-2012, 08:49 PM Thread Starter
Boomer
Actually, one coil supplies ignition source to two plugs (one coil for the front cylinder plugs and one coil for the real cylinder plugs). I've replaced the spark plug high tension lead cap and plan to monitor the spark plug. If the new spark plug cap doesn't solve the problem, my next task is to swap the plug wires from right to left on the rear spark plugs. Thanks for the reply.
Michael
'08 Meanie SE
Sponsored Links
Advertisement
post #4 of 9 (permalink) Old 08-12-2012, 09:53 PM
Senior Member
Try swapping coils to see if the problem moves to the front cylinder is what I meant.
sfair is offline
post #5 of 9 (permalink) Old 08-14-2012, 09:42 AM
Member
Vulcan Hammer's Avatar
If your bike doesn't ping with Mid Grade Gas, try running it for a tank or two and then check your plugs. You are more likely to foul plugs with premium gas if the compression ratio of your bike does not require it.
Unfortunately with most Kawi's, it is normally a timing issue that demands premium fuel. The engines are still relatively low compression designs, but Kawi sets the timing based on EPA requirements, hence the need for premium/high octane fuel. The higher the octane, the more combustion inhibitors, and the greater the tendency to foul due to incomplete combustion.
If that doesn't work, you could try swapping the darker plug with a slightly "hotter" version. "Hotter" does not mean a stronger or hotter spark, it simply means the plug retains more heat which encourages more complete combustion and helps to burn off any deposits on the tip. The danger of using a hotter plug is that it can, in some cases, cause predetonation (pinging) with low octane fuels.
Vulcan Hammer is offline
post #6 of 9 (permalink) Old 08-15-2012, 07:58 AM Thread Starter
Boomer
yep, that's the task following "swap the rear high tension leads"....sounds like we're on the "same page"....thanks.
Michael
'08 Meanie SE
post #7 of 9 (permalink) Old 08-15-2012, 11:37 PM
Nobody Home
This is a long shot but you might look at how your spark plugs are indexed. On many motors it's not a big deal but the 1500/1600 Vulcans seem to like the plugs indexed. Side electrode weld to to outside of the cylinder. 12mm indexing washers (which can be hard to find) are available here: YourOilShop - Spark Plugs and Indexing Washers for Harley-Davidson Motorcycles
BillyBobby is offline
post #8 of 9 (permalink) Old 08-17-2012, 02:28 AM
Junior Member
My old Vulcan did that for a while, especially in the early spring and late fall when the ambient starting temperature was a little colder. I did end up trimming the spark plug leads and replacing the boots and that helped a great deal. i think it must have been arcing inside the boot a bit.
KarateMoto is offline
post #9 of 9 (permalink) Old 10-20-2012, 08:53 AM Thread Starter
Boomer
PROBLEM SOLVED!!!! After replacing the plug cap, I've logged about 1900 miles including a five-day 1400 mile ride that covered most of the Blue Ridge Parkway. Inspection of the plugs revealed no fouling of the plug. The plug insulators on all four plugs looked the same. I'll put this one in the "done" file. Thanks to all for your comments.
Michael
'08 Meanie SE
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
