Oil Change 1985 700 LTD - Kawasaki Motorcycle Forums
post #1 of 4 (permalink) Old 05-12-2019, 12:20 PM Thread Starter
Junior Member
Post Oil Change 1985 700 LTD
I recently just purchased a 1985 Kawasaki 700 LTD and want to change the oil and oil filter. Where is to bolt to drain the oil on this type of bike and where is the oil filter located as well?
Miletorbs is offline
Sponsored Links
Advertisement
post #2 of 4 (permalink) Old 05-12-2019, 12:24 PM Thread Starter
Junior Member
Post Changing Oil 1985 700 LTD
I recently just purchased a 1985 kawasaki 700 ltd. It is my first bike and I need help locating where to drain the oil and where the oil filter is located.
post #3 of 4 (permalink) Old 05-12-2019, 12:45 PM
Senior Member
martin-csr's Avatar
Howdy. I have a 1981 KZ650-CSR, but doing an oil change on your bike is the same. I do the job from the RH side of the motorcycle. The oil drain plug is under the engine, forward on the oil pan & near the #2 exhaust pipe clamp. The oil filter is under a starburst oil filter cover, rearward of the oil drain plug. I remove the oil drain plug first to drain the oil, then after draining, temporarily re-install the drain plug, then move the oil catch pan under the oil filter & remove the oil filter. Then remove the oil drain plug again after installing a new oil filter. Be sure to torque the bolts properly & don't over-tighten them to avoid stripping or damaging anything.
Manuals. The owner's manual has info for changing the oil. Also, if you need the Kawasaki service manual, search EB for KZ750 Shaft manual & get the one that covers your year, or at least thru 1984. Kawasaki service manuals have a model application chart on the back cover, so make sure your bike is included on the list. I'm pretty sure the 84 & 85 ZN700 models are virtually identical, so you could get the manual thru 1984. I would prefer the thru-85 manual, but the one thru 1984 should suffice.
martin-csr is offline
Sponsored Links
Advertisement
post #4 of 4 (permalink) Old 05-12-2019, 03:11 PM
Senior Member
Here is one on EB.
https://www.ebay.com/itm/KAWASAKI-KZ...QAAOSwUDZcylR0
1985 Kawasaki ZN700 Shaft, 4cyl
1989 Yamaha Venture Royale
2007 Yamaha Royal Star Venture
RoadRunner322 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
