Recommendations on lowering a VN800 - Kawasaki Motorcycle Forums
post #1 of 18 (permalink) Old 04-26-2007, 02:13 AM Thread Starter
Senior Member
CustomVN's Avatar
I know this has probably been covered before, but searching didn't really show anything.
Can anyone make and recommendations on lowering the rear of a VN800. I know Cobra and probably Scoot Works have kits to do it, but who's actually had success? I don't want to order something from the US that doesn't actually work, or doesn't fit like it should.
CustomVN is offline
Sponsored Links
Advertisement
post #2 of 18 (permalink) Old 04-26-2007, 03:28 AM
Yet another 800 Bobber...
Thullan's Avatar
Hi!
The Cobra and Highway Hawk kits are almost identical and both are crap. You have to compress and modify the shock itself, which is a bloody **** unless you have the tools. And it is an expensive kit considering what it consists of and the result it gives. The bike will only get 2cm lower, hardly seen at all. The advertisments sometimes says 4 cm but that is bullsh*t.
The Scootworks kit costs more but it is the only kit that actually gives a result as far as I know, haven't tried it myself though. You could get the same result by extending the stock links on your own, which involves cutting and welding (instructions).
There is another method that I came up with myself while mounting the Highway Hawk kit. The result is exactly the same but you need no new parts, no drilling, cutting or welding. A similar method is described at the bottom of the site I linked to above, but I have attached a sketch showing an even better way of doing it. It's all about letting the locking nut and the U-shaped bracket swith place with eachother, giving a shorter shock. It will also increase the preload on the spring a bit, so you might want to compensate for that with the 7-step preload ring on the shock.
Currently a VN800A 1995 and a Harley-Davidson FXST 2001
Thullan is offline
post #3 of 18 (permalink) Old 04-26-2007, 04:15 AM Thread Starter
Senior Member
CustomVN's Avatar
Looking at the site you included, I don't like the idea of redrilling the shock clevis with the new hole overlapping the old, surely this would create some kind of play in the suspension?
I like your idea of swapping the lock nut and U-shaped bracket though, I can't see why that's not he best idea of the lot. Did you end up doing that Thullan and what was the result? Could perhaps even use a thinner lock nut?
CustomVN is offline
Sponsored Links
Advertisement
post #4 of 18 (permalink) Old 04-26-2007, 05:48 AM
Thullan's Avatar
I should have tried this method above if I had came up with the idea before I bought the Higway Hawk kit. I don't think a thinner locking nut will make any difference. There is one thing to pay attention to though, and that is to leave atleast 1 mm of space where indicated by the red arrow in the attached drawing, or the rocker arm wount be able to pivot (se updated drawing). Please note that I haven't tried this method myself, so there may be some problems that I have overlooked!
I was first also thinking about drilling new fixing holes in the frame where the upper part of the shock attaches (just below the seat), maybe 1-2 cm above the original holes. I never tried this either, but this should be a cheap fix if it works. Would need a bit of courage to try though
Thullan is offline
post #5 of 18 (permalink) Old 04-26-2007, 07:00 AM
Banned
Get the Scootworks kit
When i had my 800 i bought the Scootworks Clevis kit. It involves compressing the spring ( which is simple ) and replacing the clevis with an aftermarket one. The instructions are very easy to follow and you don't need to buy a compressor kit for the spring. Canadian Tire spring clamps work fine. This will drop it about 1.5 inches. Or you can buy the 3 inch kit which they sell as well. I have the 3 inch one on my 900LT and believe me it worked. It was to low for the 900 though so i had to raise it to 2 inches. Theres a site called Tweaks where he describes how to do this in detail. If i can find the site i'll post it but i dont have time right now. Perhaps someone on here has the link?
VindianaJones is offline
post #6 of 18 (permalink) Old 04-26-2007, 07:55 AM
Thullan's Avatar
Yes, that's the link I submited in my previous post
Thullan is offline
post #7 of 18 (permalink) Old 04-26-2007, 09:35 AM
Senior Member
mumbles's Avatar
question?
Has anyone who has lowered the vn800 had any trouble bottoming out when going thru potholes and such?
98 Vulcan 800a (always changing)
mumbles is offline
post #8 of 18 (permalink) Old 04-26-2007, 09:18 PM
btob
btob's Avatar
Get ahold of 'texas metrics'. He's accomplished this on V2K's and 900's. He's a member of our forum, his name is Ed Macri.
This Place Is Adictive.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
btob is offline
post #9 of 18 (permalink) Old 04-27-2007, 01:24 PM
Banned
I never had any problems with my 800 bottoming out at 1.5" lowered, even with a passenger but my 900 will bottom out with a passenger at 2" so i have to be very carefull going off curbs and turning right. Its fine with just me on it though.
post #10 of 18 (permalink) Old 04-27-2007, 03:13 PM
Senior Member
mumbles's Avatar
When I first saw the vn900 my first thought was that there was to much gap between the rear fender and tire. Maybe raising the rear 1/2" will solve the problem.
Reason I was asking is because everytime I go thru railroad tracks or speedbumps I have to lift myself up a bit so it wont hit hard. She is dropped 2 3/4" in the rear. I have the preload on the spring at the stiffest setting. Oh well, it looks good though. LOL
mumbles is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
