gears won't engage - Kawasaki Motorcycle Forums
post #1 of 10 (permalink) Old 02-24-2008, 04:45 PM Thread Starter
Junior Member
Question gears won't engage
I am getting my 1987 Vulcan 88 back up and running after an extended storage of about three years. I cleaned the carbs and got the engine running with new gass and thought I would take it for a spin around the block. TO my surprize, none of the gears would engage. everything worked fine when I parked it three years ago but now, nothing but nuetral. It apears to go into first as the neutral light goes out and I think I hear it engage, but nothing when I let out the clutch.
ANy suggestions on where to start in solving this issue.
DustyV59 is offline
Sponsored Links
Advertisement
post #2 of 10 (permalink) Old 02-24-2008, 05:09 PM
Senior Member
Clutch plates could be "froze"/stuck together. One thing we used to do was to take some B-12 (chemtool not vitamins) and pour some in the oil. Then run the engine, work the clutch either with the clutch cable (lever) or manually. Then change the oil. No synthetic oil.
Good luck.
MSF Coach
VROC Member #25609
OKVROC Member #92
okiecop is offline
post #3 of 10 (permalink) Old 02-24-2008, 05:11 PM
Senior Member
warsw's Avatar
It sounds like it is actually going into gear but your clutch is not engaging. I would start buy looking at the clutch.
warsw is offline
Sponsored Links
Advertisement
post #4 of 10 (permalink) Old 02-24-2008, 05:45 PM
Member
Are you sure the transmission is actually going into first? Perhaps the clutch disks are stuck together and the clutch isn't releasing; the shift lever may be moving but not quite far enough to engage first. Shut the motor off while you think it's in first and try to push the bike in that state (without applying clutch lever). If it's in first and everything is kosher the motor will fight your progress. If it pushes easily it may actually still be in neutral; in that case you should be able to get it into first by applying pressure to the shift lever while pushing the bike (again, without applying the clutch lever). As it slips into first the bike should stop moving.
If that's how it pans out, then I'd say your clutch disks are stuck together. To free them, with the transmission fully in first, try pushing the bike (now WITH the clutch lever applied). Alternatively, you may be able to free them by starting the motor while in first with the clutch lever applied. You'll need to be careful of the bike taking off on you (use the brakes).
If the bike had a center stand, I'd say put it on the center stand, start it in first, and with the clutch lever engaged, use the rear brake to free the clutch disks.
When I bought my 440 LTD it had sat idle for at least 10 years. The clutch disks were stuck firmly together and it took quite a bit of pushing back and forth as described to free them. Once they were freed up the clutch was fine, though.
Larry
VROC #25931
800 Club #056
2005 VN800A (Blue)
1980 KZ 440A LTD (for sale)
VulcanLarry is offline
post #5 of 10 (permalink) Old 02-24-2008, 08:15 PM
dinoSnake
Guest
Posts: n/a
Did you store the bike with oil in the crankcase? After 3 years the plates may need to be resoaked / replaced - the friction plates may have either frozen up (as suggested) or dried out.
post #6 of 10 (permalink) Old 02-27-2008, 09:18 PM Thread Starter
Junior Member
Thumbs up
Thank you all very much for your suggestions. I now have my bike easily going through the gears. I utilize mauch of what you told me and was able to ride around the block the very next day. Here are the steps I took to freed up the clutch plates.
1. I didn't have any B12 , but added SeaFoam Motor Treatment to the crank case.
2. Found, as suggested, that the bike wasn't actually going into first gear, even though the neutral like would go off.
3. Utilized suggestion and put presssue on the gear lever while rolling the bike.
4. Once the bike went into gear, I pushed it forward and backward through the engine compression a few times.
5. Put the bike in second gear and rocked back and forth a few times for good measure.
6. Started the bike and was able to shift gears easily while going around the neighborhood.
I plan to run a partial tank of fresh gass through to make sure the SeaFoam has a chance to do its job in the crankcase and then I will change the oil and plugs and work on an actual tune-up.
Thaks for all your help. This is the first time I have been on this forum and I am impressed with the help I received.
DustyV59 is offline
post #7 of 10 (permalink) Old 02-29-2008, 02:31 AM
Cruisin above overcast.
spitfire9's Avatar
Glad to hear this one worked out, and thanks for the update. More bike repair knowledge to store away for possible future use.
'07 Plasma Blue Kawasaki 900 Custom.
'85 Yamaha Venture Royale 1200
Aviation and history fanatic.
spitfire9 is offline
post #8 of 10 (permalink) Old 07-30-2018, 05:07 AM
Junior Member
Good luck.
Why don't you recommend synthetic oil?
rapfl is offline
post #9 of 10 (permalink) Old 08-02-2018, 07:08 AM
Grade "A" Poser
Hilts's Avatar
Garage
This is a zombie threat as it is now 10 years old. You're not going to get a response from the poster as he has not been on the forum since 2011.
[SIGPIC][/SIGPIC]
2003 Vulcan 800 Classic - Metallic Ruby Red
2010 Harley Davidson Electra Glide Ultra Limited
Hilts is offline
post #10 of 10 (permalink) Old 08-02-2018, 09:56 AM
Senior Member
Killjoy! With the promise of an oil thread you had to pour cold water on it hehehe
wiredgeorge
Texas Hill Country
wiredgeorge is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
