how much oil? - Kawasaki Motorcycle Forums
post #1 of 9 (permalink) Old 03-31-2007, 03:10 PM Thread Starter
Junior Member
how much oil?
Changed the gear oil in 2002 kx 65. Used hp 80w85w. It is shifting real hard now? Did I not put enough in? It looks pretty full in the window when cold?
vinny sal is offline
Sponsored Links
Advertisement
post #2 of 9 (permalink) Old 03-31-2007, 06:13 PM
Senior Member
FPMXer's Avatar
With the bike on level ground the oil should be about half of the site glass. To get it right all the time purchase a BillyWho oil bottle and it's marked on both sides of the bottle in liter's and CC's and you can always make sure it's right. But before I rode it again I would ensure the oil level is correct or the gears will burn up.
86' 250R Trike
88' LT500RJ Quadzilla
My blood is yellow and red!
FPMXer is offline
post #3 of 9 (permalink) Old 03-31-2007, 06:28 PM
Senior Member
I use mobil 1 in 10/30 and the tranny on my 03 kx100 and fill between the lines on the sight glass... shifts smooth as butter
corvettesR1 is offline
Sponsored Links
Advertisement
post #4 of 9 (permalink) Old 03-31-2007, 11:59 PM
Member
Seems pretty thick. A good transmission fluid would be better.
2000 ZX6r Mine
2002 ZX636 Hers
Big Willy is offline
post #5 of 9 (permalink) Old 04-01-2007, 09:51 AM Thread Starter
Junior Member
Oil is to the top of the glass. Rode it real quick and the gears are sticky and shifting hard. Should I try a diffrent oil? Is there to much oil in there?
post #6 of 9 (permalink) Old 04-01-2007, 04:14 PM
Member
On second thoughts, I would get rid of it real quick considering your clutch runs in it as well.
Run some auto trans in it, drain after 10 mins and refill again halfway up the window when the bike is perfectly upright.
2000 ZX6r Mine
2002 ZX636 Hers
post #7 of 9 (permalink) Old 04-01-2007, 08:03 PM
Senior Member
motodemon172's Avatar
the oil is only in the clutch.the engine is lubed with the oil in the gas.ive always used kawachem 10w40 in all my bikes.2003kx65,2003rm85,1997kx250,and 2006kx450.excellent oil made specific for wet clutches.many people like to use automotive oils(big debate)(can of worms)but i like motorcycle specific oil.80w85w is to thick for clutch use.as far as filling put some in and then pump the kickstarter by hand a couple time then let it settle.the oil should be halfway on siteglass.
just my 2cents.
2006 kx450f - 2008 kx250f - (Honda Killas)
motodemon172 is offline
post #8 of 9 (permalink) Old 04-02-2007, 02:44 PM
Member
GONZOKX's Avatar
You use a Mobil 1 10/30 in your tranny. I want to change to a good synthetic and if im understanding you right you put motor oil disigned for a auto in your 2 stroke bike? Can you let me know if im right cuz i might try it. My sons kx 65 dosent shift very smooth at all.
GO BIG OR GO HOME
GONZOKX is offline
post #9 of 9 (permalink) Old 04-02-2007, 05:22 PM
Senior Member
Yes my bike is a new 04 got it left over ..I used Mobil 1 synthetic every time so far .. The Owners manual suggests a range of oils between 10-30, 10-40, 10-50 and 20-50..... 10-30 is used when the weather temps are 14 degrees to 86 degrees. That covers MY Winter conditions to hot Summer really but in hot summer I could go to a 10-40 which will increase the protection from14 degrees to 104 degrees F. I would like to say that my kx100 has one of the nicest shifting transmissions I have ever felt on any bike .That was one thing I noted about the bike right away ..I change My oil about every 3rd ride. The bike only takes about 1/2 quart so its not alot of money .Hope this helps you out with your sons kx65.One other thing I would like to add,each container of oil has API ratings on the can .Im sure you have seem them . You should make sure you see one of these ratings SE,SF,SJ,SH or SJ with JASO MA on the can .Hope this helps..
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
