1986 600 Ninja with weak spark - Kawasaki Motorcycle Forums
post #1 of 8 (permalink) Old 03-23-2009, 10:11 AM Thread Starter
Junior Member
I have an '86 600 with a weak spark condition. It is weak enough that it doesn't even try to start. I have measured the resistance on the primary and secondary side of the coils and everything looks normal. I checked/cleaned the pickup coil and replaced the spark plugs. The battery voltage is good and the the engine turns over freely.
Im looking at the IC Igniter as the culprit but I dont know a lot about it.
Any help would be greatly appreciated.
wickettoby1 is offline
Sponsored Links
Advertisement
post #2 of 8 (permalink) Old 03-23-2009, 11:18 AM
Senior Member
Ericthejet's Avatar
99% of the time in a case like this the battery is the culprit.
It may be able to turn the engine but lacks enough juice to properly fire the plugs resulting in a weak spark.
Battery age? Load tested?
At least 13.0 volts?
1984 Ninja 900 (A1)
To make it go faster I need to add more lightness!
Ericthejet is offline
post #3 of 8 (permalink) Old 03-23-2009, 12:20 PM Thread Starter
Junior Member
Its got a new battery and I even had the charger on it.
I really dont think that its a battery issue but I will investigate it further.
Sponsored Links
Advertisement
post #4 of 8 (permalink) Old 03-23-2009, 04:20 PM
Senior Member
check the ends of your plug wires. if they're corroded, and on such an old bike this is possible, they'll give weak spark. you can clip about 1/4" off each wire end to clean up the connection real good, and it'll work great again.
ZedX 1k owner. henceforth The bike shall be Zed.
Lawn Masters is offline
post #5 of 8 (permalink) Old 03-23-2009, 05:11 PM Thread Starter
Junior Member
The spark plug boot just threads onto the wire correct?
post #6 of 8 (permalink) Old 03-23-2009, 08:58 PM
Senior Member
yes. should at least.
post #7 of 8 (permalink) Old 03-24-2009, 12:43 PM
gdb
Member
i had a similar problem on my 86 gpz600r the (new) coils measured fine for resistance but the bike kept dropping onto two pots. Replaced both coils with different ones. everything fine.
They may read ok when the bike isn't running but any load on the coils could be enough to kill them.
gdb is offline
post #8 of 8 (permalink) Old 03-25-2009, 09:07 AM Thread Starter
Junior Member
Thanks for the info. Now I don't seem to be getting any spark at the plugs so I'm going to have to go back to square one and check everything again.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
