Unrestricting Zephyr 750 C1 - Kawasaki Motorcycle Forums
 1Likes
post #1 of 25 (permalink) Old 08-13-2019, 03:46 PM Thread Starter
Junior Member
Question Unrestricting Zephyr 750 C1
Hello,
I am from Sweden and the bike is also bought there. I found out when reading the registration papers of the motorcycle, that it is restricted from 53 kW (71bhp) to 37 kW (49bhp)by restriction added to carbs. I also found out that ALL Zephyrs sold in Europe were restricted due to emission standards to be met.
I tried to look for cable, shims, draughts etc restriction and found none. Until I checked the diafragm slide and I found out there is 4 holes drilled in there, two at each side. When consulting Haynes book and/or looking at spare parts in US I do not see any hole in the slide. They're also very expensive to afford buying new spares from US. So, my plan, is to add chemical metal and plug those holes. However, should I plug all those 4 holes or is it just one of them? I become unsure which holes I should go for.
I will add two photos, I hope you can help my Zephyr to breathe real wind again!
A bit dark on the right side, but its a hole there too. This side faces the valves
This side face airbox
There is also a hole at the bottom however it's as it should be, from what I gather.
Thanks in advance!
TimOfSweden is offline
Sponsored Links
Advertisement
post #2 of 25 (permalink) Old 08-13-2019, 06:51 PM
Junior Member
DannZ's Avatar
Garage
Hi, I've seen several different carb rebuild kits on E-bay and none of them showed any holes in the diaphragm slide.
https://www.ebay.com/itm/Motorcycle-...MAAOSw7nZatG3N
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
DannZ is offline
post #3 of 25 (permalink) Old 08-13-2019, 07:43 PM
Junior Member
DannZ's Avatar
Garage
... also manufacturer (P/N:16126-1160) shows no holes on either side. Good luck!
TimOfSweden likes this.
DannZ is offline
Sponsored Links
Advertisement
post #4 of 25 (permalink) Old 08-14-2019, 04:08 PM Thread Starter
Junior Member
I bought chemical metal and goddamnit the fumes was noxious and probably not good for health. However added it and it dried metal hard almost at once.
I'll let them dry over the night, tomorrow, I will mount it all back and go for a test ride!
post #5 of 25 (permalink) Old 08-14-2019, 06:15 PM
Junior Member
DannZ's Avatar
Garage
Sounds good. Hopefully that "chemical metal" is fuel resistant and doesn't dissolve.
You may have to make some carburetor adjustments to account for the plugged holes.
DannZ is offline
post #6 of 25 (permalink) Old 08-15-2019, 03:48 AM Thread Starter
Junior Member
It is fuel resistant and doesn't melt until temperature is over 160 degree Celsius (320 degree Fahrenheit).
I might, will have to ride first and check plugs afterwards.
post #7 of 25 (permalink) Old 08-15-2019, 05:09 AM
Senior Member
Hugojose's Avatar
No, in the US they do not have the 4 holes. The one in the bottom is only an indentation, not a hole, I presume to indicate the orientation of the slide. The indention should face the intake side.
Hugojose is offline
post #8 of 25 (permalink) Old 08-15-2019, 07:01 AM Thread Starter
Junior Member
I put everything back in, went out for test ride. Let it warm properly first. And then tried WOT, results:
positive
# It revs much faster when using clutch or no gear in.
# Very aggressive rev/acceleration when in high range rpm.
negative
# Much more apparent stuttering (hestitation) in midrange, its like its starved for fuel when WOT around 4-5k rpm. With that I mean it is not smooth power transistion as when above 8k rpm.
What can I learn from this? Is jetting bad for such fast power surge when wot?
post #9 of 25 (permalink) Old 08-15-2019, 01:16 PM
Member
You could try raising the needles a couple of notches, it sounds like itís being starved of fuel in the mid range.
davidr1963 is offline
post #10 of 25 (permalink) Old 08-15-2019, 01:18 PM Thread Starter
Junior Member
positive
negative
Countinuation of latest reply!
Ok, went out for another ride. Still same symptoms, motorcycle do not bog. It's just like when riding against heavy winds. Acceleration do not have linear power output all the way, there is weakness there and there. As if it would be starved and not getting full fuel power as needed. Mid-range is where problem lies. No hestitation or bogging when idling and wot.
Pulled out the spark plugs and they look like this;
I know Zephyr 750's are oil and air cooled, so they generally runs hotter than nowadays fluidcooled machines. However if you ask me, I would say it runs too lean/hot. I think the carb setup is original/untouched.
However it's just a laymans give and take.
So before going to clean carbs and s*** which is just bothersome, I would like to add S1 injectioncleaner and rejet to make it go richer.
My questions, what jetting should I go? You who have no holes in slide in US, which jetting? Help me!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
