Recently changed starter. - Page 2 - Kawasaki Motorcycle Forums
 2Likes
post #11 of 25 (permalink) Old 09-03-2017, 08:08 AM Thread Starter
Junior Member
Tuned841100's Avatar
Bumping I mean push starting. And I used a circuit tester to determine that nothing was drawing the power.
Tuned841100 is offline
Sponsored Links
Advertisement
post #12 of 25 (permalink) Old 09-03-2017, 08:14 AM Thread Starter
Junior Member
So I don't have an actually battery tester. I am Just getting my volt count off the volt meter on the bike. Should I take battery in to get it load tested?
post #13 of 25 (permalink) Old 09-05-2017, 09:56 AM
Senior Member
martin-csr's Avatar
Yes. With any electrical problems, the first thing you should do is make certain the battery is good. I had a total loss of electrical power a few weeks ago but didn't think it was the battery because it was an AGM battery and it was exactly 2 yrs old & well maintained. So I tested a bunch of stuff, without load testing the battery. The problem was the battery. doh.
martin-csr is offline
Sponsored Links
Advertisement
post #14 of 25 (permalink) Old 09-05-2017, 10:56 AM
Senior Member
1. What is a circuit tester?
2. Factory bike mounted voltmeters are rarely accurate enough for battery testing.
sfair is offline
post #15 of 25 (permalink) Old 09-05-2017, 06:46 PM
Senior Member
Hugojose's Avatar
....and to actually determine if something if draining the battery, you actually have to read if any CURRENT is drawn when bike is off.
Hugojose is offline
post #16 of 25 (permalink) Old 09-05-2017, 09:33 PM Thread Starter
Junior Member
I did a circuit test and determined that nothing was draining the battery when it is off. I have not done a load test but I am about to do a multimeter test on it now.
post #17 of 25 (permalink) Old 09-05-2017, 10:05 PM
Senior Member
And I ask again, what is a "circuit tester"?
sfair is offline
post #18 of 25 (permalink) Old 09-06-2017, 12:05 AM Thread Starter
Junior Member
A 12 volt circuit tester checks for shorts and grounds. Basically it's a light on a wire with alligator clips at the end. You would put the clamps onto the negative wire and then touch the other end on the negative terminal.(wire disconnected from negative terminal and bike off)
Then if the light comes on and stays on something is draining your battery.
Aside from that I just used a multimeter to test my battery and I got 12.87 with bike off and again 12.87 with bike running. Also if I give it gas the volts go up to 13.80 then when you release the throttle they drop back down to 12.87
post #19 of 25 (permalink) Old 09-06-2017, 11:01 AM
Senior Member
1. A light bulb is not sensitive enough to check for a low amperage draw. 2. Those voltage readings look OK. 3. Are you still having the starting issues?
sfair is offline
post #20 of 25 (permalink) Old 09-06-2017, 11:15 AM Thread Starter
Junior Member
Well since I've recharged the battery I haven't had any issues. Just hope I'm not out one day and all of a sudden the bike won't start. What is weird is leading up to the day my bike wouldn't start the tachometer would go all screwy and jump from say 4000rpm to 7-8000 then back to proper rpms. The engine was fine wasn't hesitating or anything like that. Just the Roma wouldn't stay calm.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
