95 Kawasaki vulcan carbs - Kawasaki Motorcycle Forums
post #1 of 10 (permalink) Old 04-11-2019, 05:03 PM Thread Starter
Junior Member
I want to rebuild my carburetors my bike has been sitting for about six years. Does anyone know a good kit to buy with the gaskets. I just want to clean everything up inside and not replace too much unless you think I would have to .
vulcandar is offline
Sponsored Links
Advertisement
post #2 of 10 (permalink) Old 04-11-2019, 11:38 PM
Senior Member
Usually, you can find K&L parts on fleabay. Probably all you need are the needle and seats. However, if the carbs are CV carbs, the rubber diaphragms could be leaking. I would buy a weld tip cleaner for cleaning the tiny passages in the carbs. what model Vulcan do you have?
https://www.ebay.com/itm/13-Welding-...IAAOSw~slcUMfb
1985 Kawasaki ZN700 Shaft, 4cyl
1989 Yamaha Venture Royale
2007 Yamaha Royal Star Venture
RoadRunner322 is offline
post #3 of 10 (permalink) Old 04-12-2019, 07:53 AM Thread Starter
Junior Member
I have a 95 Kawasaki vulcan en500
Sponsored Links
Advertisement
post #4 of 10 (permalink) Old 04-12-2019, 09:25 AM
Senior Member
https://www.ebay.com/itm/kawasaki-ca...wAAOSw6rda5707
The K&L kits are made in Japan and are quality made parts.
post #5 of 10 (permalink) Old 04-12-2019, 06:57 PM Thread Starter
Junior Member
Thanks for the info. Is there a gasket at the top of the carb I would need need after checking out diaphragm. I can’t find any
post #6 of 10 (permalink) Old 04-12-2019, 07:05 PM
Senior Member
I don't think you will need anything else. I usually buy OE parts from partzilla.
post #7 of 10 (permalink) Old 04-13-2019, 10:03 AM
jpd
Junior Member
Garage
I think that the diaphragm is the seal for the top cover. It is rubber and should pinch between the cover and carb.
jpd is offline
post #8 of 10 (permalink) Old 04-13-2019, 04:53 PM Thread Starter
Junior Member
Gotcha makes sense thanks!
post #9 of 10 (permalink) Old 04-14-2019, 05:53 PM
Junior Member
I just replaced my batter on my 05 Vulcan and it doesn’t turn over fully...everything comes on but just won’t fully start, any suggestions would help
Candace0822 is offline
post #10 of 10 (permalink) Old 04-14-2019, 06:59 PM
jpd
Junior Member
Garage
Turn over fully and start fully are two different things. Will it crank strong? (turn over) or not start to run? (fully start). I am going to guess that it is cranking due to the new battery. Not starting would then be no spark or no/ bad fuel. If you have spark, drain the tank add new fuel and try again. Even with new fuel if the carbs are dirty or plugged due to old/ bad fuel. They would need to be cleaned. Also remember that if it has sat for a long time the fuel will have evaporated out of the carbs and you will have to crank for an extended time for the vacuum petcock to open and fill the carbs. If you have a prime position on the petcock you can use that to fill the carbs.
jpd is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
