My “new” 1995 vn1500A - Kawasaki Motorcycle Forums
post #1 of 5 (permalink) Old 05-10-2019, 06:42 PM Thread Starter
Junior Member
Hey guys,
Hoping some of you will be able to help. I just bought a 1995 VN1500A with the intentions of restoring it. It has no fire going to the plugs, a slow turnover, and the headlight will not turn on. The batter is brand new (3 days old) and is showing a reading of 15.62V. When testing it and while trying to start I get an initial reading of 13, then 11, then 8 as it slowly drains the battery. I have also checked the starter relay and it seems to be working properly. Any advice you guys could give me on this would be greatly appreciated. Also, I have 2 wires (white/blue, and yellow/black) disconnected by the battery box and they run all the way into the headlight bucket and are unplugged there. the white/blue wire seems to be connected to power somewhere in between because its giving me a "15.something"V reading. while the yellow/black gives no reading. The fuel pump seems to be inactive too. I hear no noise when I turn the key to the "on" position. I ordered a new one thinking it would be best to go ahead and replace it but the knew one is doing the exact same thing. I've ordered a Clymer's manual but hoping you guys could give me some info to try to trouble shoot these issues while I wait for it to arrive next week. Thanks in advance for any help and information you guys can offer.
rannman92 is offline
Sponsored Links
Advertisement
post #2 of 5 (permalink) Old 05-11-2019, 06:44 PM
Junior Member
The fuel pump only comes on when the carb needs more gas. My 1996 does the same thing. When I drained the carbs, the pump started running the minute you switch it on, because the carbs were empty. If it is full when you turn it on the pump will not run until the carb needs more fuel. hope this helps you. I learned this the hard way, i also changed the pump, all for nothing.
snortster883 is offline
post #3 of 5 (permalink) Old 05-11-2019, 08:52 PM
Senior Member
I recommend you disconnect and clean every electrical connection you can find and get to. Remove as much stuff as needed. Also 15.62 volts is too high. Your meter is suspect. The meter might need a new battery. I discovered that my multimeter would read voltage at higher than actual when it needed a new battery.
1985 Kawasaki ZN700 Shaft, 4cyl
1989 Yamaha Venture Royale
2007 Yamaha Royal Star Venture
RoadRunner322 is offline
Sponsored Links
Advertisement
post #4 of 5 (permalink) Old 05-11-2019, 10:43 PM Thread Starter
Junior Member
I changed the pump earlier just to be sure. I appreciate the info though. Good to know!
post #5 of 5 (permalink) Old 05-11-2019, 10:49 PM Thread Starter
Junior Member
Just changed the battery in it and it’s ready 13.2v with the ignition switch on. I changed the ignition coils and the plug wires and charged the battery on the bike and now I have a slightly faster turn over and the headlight is now coming on when hit the start switch. But still no spark to the plugs. I’m going to start cleaning all of the connections tomorrow. Thanks for the advice!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
