Vacuum line connection on 82 Kawasaki 750 csr - Kawasaki Motorcycle Forums
post #1 of 3 (permalink) Old 08-25-2019, 05:18 PM Thread Starter
Junior Member
Hello all ok new question I'm having trouble with the vacuum line I see the ones that go to the carb from the air box then I have a tee with a line connected to it and on the carb I see 2 connection I know one is for the fuel tank but the other I have no clue I'm I missing a tee for the vacuum from tank to carb or something
Cruzn74 is offline
Sponsored Links
Advertisement
post #2 of 3 (permalink) Old 08-26-2019, 08:23 AM
Senior Member
martin-csr's Avatar
I'm assuming you have the stock vacuum petcock, and the clean air system stuff is still connected.
If you check the air cleaner diagram drawing at Partzilla & look at the smog lines, notice there is a T fitting & also a Y fitting closer to the fat air switch valve. I think the line on the Y fitting is for the vac port on the petcock. The lines from the T fitting go to the vac ports on the carburetors.
martin-csr is offline
post #3 of 3 (permalink) Old 08-26-2019, 11:14 AM Thread Starter
Junior Member
Ok I see that but what about the "vacuum port" on the carb what goes there and where would that connect to
Cruzn74 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
