Oil drain round off help - Kawasaki Motorcycle Forums
post #1 of 9 (permalink) Old 08-30-2019, 06:48 PM Thread Starter
TOP
Member
Trying to change my My oil but bolt so round of any good suggestion how to remove
TOP is offline
Sponsored Links
Advertisement
post #2 of 9 (permalink) Old 08-30-2019, 09:04 PM
Senior Member
If the bolt head is sticking out, vise grip pliers, or grind two sides flat and use an adjustable wrench. If the head is sunk in and you use an allen head or something similar that will be a lot harder.
1985 Kawasaki ZN700 Shaft, 4cyl
1989 Yamaha Venture Royale
2007 Yamaha Royal Star Venture
RoadRunner322 is offline
post #3 of 9 (permalink) Old 08-31-2019, 07:41 AM
Senior Member
martin-csr's Avatar
Large vice grips. and tap it with a hammer to spin it if necessary. just in case. be sure to turn the bolt in the correct direction. you never know sometimes, but some guys get it wrong since the oil drain plug is under the motorcycle.
martin-csr is offline
Sponsored Links
Advertisement
post #4 of 9 (permalink) Old 08-31-2019, 05:09 PM Thread Starter
TOP
Member
I will give that a try .the way I determine the with my drill direction that is good way yes or no THANKS I will let you how it works
TOP is offline
post #5 of 9 (permalink) Old 08-31-2019, 05:24 PM
Stoopit Moderator
rbentnail's Avatar
Righty tighty, lefty loosey. When looking directly at the head of the bolt, counterclockwise loosens.
Words aren't children and there's nothing wrong with killing them to clarify a point or keep the peace.
rbentnail is offline
post #6 of 9 (permalink) Old 09-01-2019, 10:30 AM
jpd
Member
Garage
You might try a pipe wrench. They are designed to work on round pipes, and bite harder the more you pull. Did you get a new drain plug to replace it?
jpd is offline
post #7 of 9 (permalink) Old 09-01-2019, 12:48 PM Thread Starter
TOP
Member
No I just wanted to get it out frist I might have to use a dremel tool get two flat sides, going know where with a file
TOP is offline
post #8 of 9 (permalink) Old 09-02-2019, 11:23 AM
Member
A Weil Adjustamatic 8" speed wrench will usually take out rounded-off bolts or nuts that size if you have room to get it on there.
The 6" also works great on brake line nuts etc. the larger wrench sizes are good for iron pipe fittings etc. The 3-surface grip is key to how they work. Harder you pull, the more the teeth dig in.
Several on Ebay now: https://www.ebay.com/itm/Weil-8-Adju...YAAOSwz~ZdZV5x
There are several other companies making similar ones now.
The other suggestions are also good.
9094 is offline
post #9 of 9 (permalink) Old Today, 03:04 PM Thread Starter
TOP
Member
Have anyone use a pneumatic exacuator to remove remove their oil ? I got one that came in today let me know if you have thanks
top.
TOP is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
