Piston guestion - Kawasaki Motorcycle Forums
post #1 of 4 (permalink) Old 10-29-2018, 12:50 PM Thread Starter
Junior Member
andersiarsta@ownit.nu's Avatar
Piston guestion
Hi everybody,
I am going to fit new pistons in my bike
and because of that i have a question i hope you people can help me with.
Does anyone know how much the oversize is when the piston is marked with 1+.Is the piston1 mm larger in diameter than a original piston?
The bike is a 1982 550 gpz unitrack.
Thank's in advance
Sponsored Links
Advertisement
post #2 of 4 (permalink) Old 10-29-2018, 01:39 PM
Senior Member
martin-csr's Avatar
I don't know. Are these Kawasaki pistons? Do you have new piston ring sets? And do you have the Kawasaki factory service manual? I would think you're going to need a good caliper & need to do some measuring, and I would also think you could/should measure the pistons.
I looked up the KZ550-H1 GPz pistons on Partzilla & eebbaaay.
The 13027-1058 OS pistons have 100 stamped into the top of them.
The 13029-1062 OS pistons have 50 stamped into the top & one seller says it's the 1st oversize.
The 550 manual says there are 2 oversize pistons available, 0.50mm OS & 1.00 mm OS.
Regarding the numbers stamped into the tops: I would assume 50 = 0.50 mm OS & 100 = 1.00 mm OS.
For comparison, the KZ550-A3 pistons are stamped with 0.50 & 1.00, and the parts diagrams more clearly differentiate between the two.
The 13029-1055 piston has 0.50 stamped into the top & listed as PISTON-ENGINE L,O/S 0.50.
The 13027-1053 piston has 100 stamped into the top & listed as PISTON-ENGINE LL,O/S 1.00.
I assume L = 1st oversize (0.50 mm) & LL = 2nd oversive (1.0 mm).
martin-csr is offline
post #3 of 4 (permalink) Old 10-29-2018, 03:10 PM Thread Starter
Junior Member
Thanks for the quick reply martin.
Yes it's Kawasaki pistons.
I'm almost sure that i have to buy new pistons & rings because bad compression.The cylinder head and valves seems to be good.
I come to the same conclusion. I will measure the cylinders and pistons so I can order the right overzise pistons "L 0.50mm or LL1.0mm"
Once again thanks for the help martin!
Sponsored Links
Advertisement
post #4 of 4 (permalink) Old 11-05-2018, 08:02 PM
Senior Member
martin-csr's Avatar
Engine work is beyond my abilities, but another possibility for the low compression could be the valve stem seals as they can get hard over time & may not seal properly.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
