How do I tension the cam chain on a 1990 Kawasaki ZR550? - Page 2 - Kawasaki Motorcycle Forums
post #11 of 13 (permalink) Old 08-19-2019, 04:51 AM
Member
The partzilla catalogue shows that youíve a stock automatic tensioner.
Unless the cam chain is worn beyond its limit then thereís nothing for you to do.
As said above, they all sound a bit rattly as they have both cam drive and primary drive chains.
https://www.partzilla.com/catalog/ka...haft-tensioner
davidr1963 is online now
Sponsored Links
Advertisement
post #12 of 13 (permalink) Old 08-20-2019, 06:27 PM Thread Starter
Junior Member
Hugojose/davidr1963: Thanks for your great input. It really helps.
I do intend to check the valve clearances. Is there a way to also evaluate the cam chain for ware and tightness while I have the top covers off?
Thanks!
AZFIREBALL is offline
post #13 of 13 (permalink) Old 08-20-2019, 08:25 PM
Senior Member
Hugojose's Avatar
I believe the Kawasaki service manual would say 20-links should be between 127 and 127.4 mm. Service limit at 128 mm. Again, I have the 750, and the 550 is very similar, but unless something was abused real bad, even at 64k km, I would not worry too much about. this is to say, unless the cam chain tensioner runs out of play, there should not be any problem....
…...remember this, cars have the engine way out there in front, and most of them (OHC or DOHC) have rubber belts, not chain, thus sound very quiet. This is an DOHC air cooled engine between your legs with a metal cam chain...….actually three, with the primary drive, and final drive.
…..checking valve clearances, or worse, adjusting clearance, have some tricks. This is a shims under bucket design, and it takes removal of cam shafts to adjust....if you get into that, ask for tips. In those days Kawi asked for valve clearance check every 6K miles (8K km), very exaggerate, but still after all those km, I'd rather check.
Hugojose is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
