50 steps to Stay Alive
55K views 111 replies 72 participants last post by  Lady Phoenix
#1 ·
(repost for new members)
1. Assume you're invisible.
To a lot of drivers, you are. Never make a move based on the assumption that another driver sees you, even if you've made eye contact. Bikes don't register to the four-wheel mind.
2. Be considerate.
The consequences of strafing the jerk du jour or cutting him off, start out bad and get worse. Pretend it was your grandma and smile.
3. Dress for the crash, not the pool or the pub.
Sure, McDonalds is a 5-minute trip, but nobody plans to eat pavement. Modern mesh gear means 100-degree heat is no excuse for a T-shirt and board shorts.
4. Hope for the best, prepare for the worst.
Assume that car across the intersection will turn across your bow when the light goes green, with or without a turn signal.
5. Leave your ego at home.
The only people who really care if you were faster on the freeway will be the officer and the judge.
6. Pay attention.
Yes, there is a half-naked girl on the billboard. That shock does feels squishy. Meanwhile, you could be drifting toward Big Trouble. Focus.
7. Mirrors only show you part of the picture.
Never change direction without turning your head to make sure the coast really is clear.
8. Be patient.
Always take another second or three before you pull out to pass, ride away from a curb or into freeway traffic from an on-ramp. It's what you don't see that gets you. That extra look could save your butt.
9. Watch your closing speed.
Passing cars at twice their speed or changing lanes to shoot past a row of stopped cars is just asking for trouble.
10. Beware the verge and the merge.
A lot of nasty surprises end up on the sides of the road: empty McDonalds bags, nails, TV antennas, ladders, you name it. Watch for debris on both sides of the road.
11. Left-turning cars remain a leading killer of motorcyclists.
Dont assume someone will wait for you to dart through the intersection. They're trying to beat the light, too.
12. Beware of cars running traffic lights.
The first few seconds after a signal light changes are the most perilous. Look both ways before barging into an intersection.
13. Check your mirrors.
Do it every time you change lanes, slow down or stop. Be ready to move if another vehicle is about to occupy the space youd planned to use.
14. Mind the gap.
Remember Drivers Ed? One seconds worth of distance per 10 mph is the old rule of thumb. Better still, scan the next 12 seconds ahead for potential trouble.
15 Beware of racers.
They're quick and aggressive. Dont assume you've beaten one away from a light or outpaced it in traffic and change lanes without looking. You could end up as a civic hood ornament.
16. Excessive entrance speed hurts.
Its the leading cause of single-bike accidents on twisty roads and racetracks. In Slow, Out Fast is the old adage, and it still works. Dialing up corner speed is safer than scrubbing it off.
17. Dont trust that deer whistle.
Ungulates and other feral beasts prowl at dawn and dusk, so heed those big yellow signs. If youre riding in a target-rich environment, slow down and watch the shoulders.
18. Learn to use both brakes.
The front does most of your stopping, but a little rear brake on corner entry can calm a nervous chassis.
19. Keep the front brake covered always.
Save a single second of reaction time at 60 mph and you can stop 88 feet shorter. Think about that.
20. Look where you want to go.
Use the miracle of target fixation to your advantage. The motorcycle goes where you look, so focus on the solution instead of the problem.
21. Keep your eyes moving.
Traffic is always shifting, so keep scanning for potential trouble. Dont lock your eyes on any one thing for too long unless youre actually dealing with trouble.
22. Think before you act.
Careful whipping around that micra going 7 kph in a 30-kph zone or you could end up with your head in the drivers side door when he turns into the driveway right in front of you.
23. Raise your gaze.
Its too late to do anything about the 20 feet immediately in front of your fender, so scan the road far enough ahead to see trouble and change trajectory.
24. Get your mind right in the driveway.
Most accidents happen during the first 15 minutes of a ride, below 40 mph, near an intersection or driveway. Yes, that could be your driveway.
25. Come to a full stop at that next stop sign.
Put a foot down. Look again. Anything less forces a snap decision with no time to spot potential trouble.
26. Never dive into a gap in stalled traffic.
Cars may have stopped for a reason, and you may not see why until its too late to do anything about it.
27 Dont saddle up more than you can handle.
If you weigh 95 pounds, avoid that 795-pound cruiser. If you're 5-foot-5, forget those towering adventure-tourers.
28. Watch for car doors opening in traffic.
And smacking a car thats swerving around some goofballs open door is just as painful.
29. Dont get in an intersection rut.
Watch for a two-way stop after a string of four-way intersections. If you expect cross-traffic to stop, there could be a painful surprise when it doesnt.
30. Stay in your comfort zone when youre with a group.
Riding over your head is a good way to end up in the ditch. Any bunch worth riding with will have a rendezvous point where youll be able to link up again.
31. Give your eyes some time to adjust.
A minute or two of low light heading from a well-lighted garage onto dark streets is a good thing. Otherwise, youre essentially flying blind for the first mile or so
32. Master the slow U-turn.
Practice. Park your butt on the outside edge of the seat and lean the bike into the turn, using your body as a counterweight as you pivot around the rear wheel.
33. Who put a stop sign at the top of this hill?
Dont panic. Use the rear brake to keep from rolling back down. Use Mr. Throttle and Mr. Clutch normally and smoothly to pull away.
34. If it looks slippery, assume it is.
A patch of suspicious pavement could be just about anything. Butter Flavor Crisco? Gravel? Mobil 1? Or maybe its nothing. Better to slow down for nothing than go on your head.
35. Bang! A blowout! Now what?
No sudden moves. The motorcycle isnt happy, so be prepared to apply a little calming muscle to maintain course Ease back the throttle, brake gingerly with the good wheel and pull over very smoothly to the shoulder. Big sigh.
36. Drops on the faceshield?
Its raining. Lightly misted pavement can be slipperier than when its been rinsed by a downpour, and you never know how much grip there is. Apply maximum-level concentration, caution and smoothness.
37. Emotions in check?
To paraphrase Mr. Ice Cube, chickity-check yoself before you wreck yoself.
Emotions are as powerful as any drug, so take inventory every time you saddle up. If youre mad, sad, exhausted or anxious, stay put.
38. Wear good gear.
Wear stuff that fits you and the weather. If youre too hot or too cold or fighting with a jacket that binds across the shoulders, you're dangerous. Its that simple.
39. Leave the iPod at home.
You wont hear that cement truck in time with Spinal Tap cranked to 11, but they might like your headphones in intensive care.
40. Learn to swerve.
Be able to do two tight turns in quick succession. Flick left around the bag of briquettes, then right back to your original trajectory. The bike will follow your eyes, so look at the way around, not the briquettes. Now practice till its a reflex.
41. Be smooth at low speeds.
Take some angst out, especially of slow-speed maneuvers, with a bit of rear brake. It adds a welcome bit of stability by minimizing unwelcome weight transfer and potentially bothersome driveline lash.
42. Flashing is good for you.
Turn signals get your attention by flashing, right? So a few easy taps on the pedal or lever before stopping makes your brake light more eye-catching to trailing traffic.
43. Intersections are scary, so hedge your bets.
Put another vehicle between your bike and the possibility of someone running the stop sign/red light on your right and you cut your chances of getting nailed in half.
44. Tune your peripheral vision.
Pick a point near the center of that wall over there. Now scan as far as you can by moving your attention, not your gaze. The more you can see without turning your head, the sooner you can react to trouble.
45. All alone at a light that wont turn green?
Put as much motorcycle as possible directly above the sensor wire usually buried in the pavement beneath you and located by a round or square pattern behind the limit line. If the light still wont change, try putting your kickstand down, right on the wire. You should be on your way in seconds.
46. Every-thing is harder to see after dark.
Adjust your headlights, Carry a clear faceshield and have your game all the way on after dark, especially during commuter hours.
47. Dont troll next toor right behind Mr. Peterbilt.
If one of those 18 retreads blows upwhich they do with some regularity it de-treads, and that can be ugly. Unless you like dodging huge chunks of flying rubber, keep your distance.
48. Take the panic out of panic stops.
Develop an intimate relationship with your front brake. Seek out some safe, open pavement. Starting slowly, find that fine line between maximum braking and a locked wheel, and then do it again, and again.
49. Make your tires right.
None of this stuff matters unless your skins are right. Dont take em for granted Make sure pressure is spot-on every time you ride. Check for cuts, nails and other junk they might have picked up, as well as general wear.
50. Take a deep breath.
Count to 10. Smile at the idiot. Forgetting some clowns 80-mph indiscretion beats running the risk of ruining your life, or ending it.
#6 ·
Excellent! I would also strongly suggest taking a motorcycle safety course. Pennsylvania offers them for free other states charge a minimum fee. More information at Motorcycle Safety Foundation. Pass the course, get your license. But it is not just that, it is experienced riders/instructors teaching the course. It consists of classroom instruction and course riding, your bike or theirs. The information I got from the course is invaluable.
#8 ·
i liked everything, except.... #19. I was told in the MSF course to keep my fingers off the front brake unless i was stopping or getting on/off the bike otherwise i might press it by accident and i might cause one. What are your thoughts?
They told me in my MSF class that they didn't want me to cover the brake INITIALLY... definitely made it sound like it would be a wise thing to do down the road though. I'm thinking this is taught perhaps in the advanced rider course? (Has anybody taken this course? What did you think of it?)
I don't recall them teaching me in my class to flash the brake lights, but I instinctively do anyway... HOWEVER - do not count on this catching anybody's attention. I got a$$ ended at a red light by a drunk driver when my bike was 5 days old.... won't be riding again until next summer. *sighs*
Jessie
#14 ·
Thanks for reposting this. It makes beginners, like myself, realize how serious the responsibility of riding really is. And for those with people relying on them, doubly so.
#19 ·
I drove past an accident this mornining. As I was coming up to it I saw the bike laying on the pavement, a couple portable screens, and a vinyl cover over the riders body near the car. A dozen cops were standing around, the fire engine was there, but no ambulance. It appears the guy rider was in the right lane on the 45 mph five lane road. The driver pulled out from the bank on the same side heading in the opposite direction trying to get across the two lanes and that was it. I don't think the driver got the car more than 8 ft. out of the driveway before the collision, maybe even less.
I thought about it after my sadness waned and it seems that in the right lane a rider doesn't have much time and not many options when a car pulls out. It seems safer to ride in the left lane because you have more time to react and more options. Also, it seems strange but I think there is an advantage to riding with some traffic vs. alone on the road if there are alot of driveways. Drivers would have less of a tendency to pull out in front of a car with a bike at least around town. Any thoughts appreciated.
#21 ·
I train people on driver safety as they regard to patrol techniques (not motorcycle patrol), and I learned some things reading that! When we teach patrol, most drivers who are experienced learn the "two second rule." Two seconds between you and the car ahead.
For patrol, since we have a lot more we should be paying attention to, we expand that to a recommended minimum "four second rule." As someone looking to get on a bike, would the more experienced here recommend that, or is it over-cautious/asking to be rear ended in traffic?
Thanks!
#22 ·
commuter / in city riding
Two other items for new riders to think about if riding in traffic in the city.
Double Left Turn Lanes.
When making left turns from a double left turn lane, always go to the median lane. This eliminates having to pull way out into the middle of the intersection to be able to see around on-coming left turn lanes.
Also, cars will more frequently swing wide (and into your lane) than cutting the corner short. Staying on the inside median lane prevents finding yourself being squeezed to the curb.
Storm Sewer Grates
If you live where there are storm sewer grates to deal with heavy run off, be very wary of them. It is tough to get traction on them and your rear tire can easily slide sideways, or get goosey on them
In our city they are often 15 feet back from the intersections. If you are stopped on top of one and start to take off for the light they can be like ice. Either stop back behind them, or if you must stop on top of them accererlate slowly when taking off.
Worse yet is if you are leaning around a corner and hit one. If you are leaning into a turn and see one, get your bike back vertical as quickly as you can or your bike can squirt out from under you. Unfortunately, I witnessed this one two days ago, the rider wasn't hurt bad but the bike slid up against a car waiting for the light.
Ride safe and enjoy!
#23 ·
When I was in the MSF course they also told me to never cover the front brake. When I took the ERC, they never said anything about covering the front brake either.
Awesome post! Something any newbie would benefit from reading every day.
Darlene
#24 ·
I use noise canceling headphones when I go on long trips sometimes. I can't hear anything anyway with all the wind noise. You just have to pay more attention to everything. Same goes for the people with helmet communicators and ear plugs.
