83 Kawasaki KZ1100 LTD Engine Repair - Kawasaki Motorcycle Forums
post #1 of 8 (permalink) Old 05-20-2015, 07:11 PM Thread Starter
Member
GalDemSuga's Avatar
Garage
Folks
It's been almost a year since I have been on the forum. Amber has been sitting in the garage but now I could use her services. She needs some top end work as she is burning oil, leaking oil at the head, leaking oil at the base cover and now starter won't work. It spins free and I believe the starter clutch is at fault.
I have began the tear down in the frame and already messed up as I forgot to label the valve buckets and was surprised to find no shims under the buckets. I will post pics and update progress soon.
GalDemSuga is offline
Sponsored Links
Advertisement
post #2 of 8 (permalink) Old 05-21-2015, 06:44 PM
Senior Member
custer's Avatar
Re: 83 Kawasaki KZ1100 LTD Engine Repair
the shims should be on top of the lifters. if you get a gasket set from z1enterprises it should have valve seals and everything you would need besides the lower/bottom of the cylinder block/jugs oil passage O-rings.
1980 kz810 h1
1983 Honda vf750
custer is offline
post #3 of 8 (permalink) Old 06-07-2015, 04:44 AM
Junior Member
The whole top end rebuild isn't nearly as daunting task as it seems. Im a pretty decent mechanic but don't think it's required to do this. Biggest thing is to label everything/take pics with phone.. You can't take too many. Most if not all machine work will be done by machine shop. Ape did my 76 Kaw 900. Punched it to 1015, honed cyl and labeled rings and pistons to cyl. If you have shop manual and tools you can do it. Don't be in a hurry. They can also port and rebuild heads.
abadrs is offline
Sponsored Links
Advertisement
post #4 of 8 (permalink) Old 01-01-2019, 09:29 PM Thread Starter
Member
GalDemSuga's Avatar
Garage
Many years later, through unemployment and a divorce, now I am getting back to Amber. I have moved to Dallas, TX and will begin to rebuild this bike this week.
post #5 of 8 (permalink) Old 01-01-2019, 10:06 PM
Senior Member
Welcome Back! Keep us updated on your progress!
1985 Kawasaki ZN700 Shaft, 4cyl
1989 Yamaha Venture Royale
2007 Yamaha Royal Star Venture
RoadRunner322 is offline
post #6 of 8 (permalink) Old 01-01-2019, 11:07 PM Thread Starter
Member
GalDemSuga's Avatar
Garage
Smile
Thank you and I will. I am sure I will need help along the way.
post #7 of 8 (permalink) Old 01-04-2019, 08:21 PM
Junior Member
Awesome, I'm a big fan of KZ's and used to live in Dallas. Looking forward to your updates.
Jimbo302 is offline
post #8 of 8 (permalink) Old 01-05-2019, 12:13 PM
Junior Member
i did an '83 gpz1100 last year that had the shim buckets out and scattered (shim under). some were even slightly rusty. i refitted by oiling up and trying a fit, using a magnet to check ease of movement in the bore. after 500 miles so far, so good.
ned37 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
